#16 |
Downconverting in the camera is going to give you the poorest quality from HDV. Best method, tho takes a lot of rendering time, is to cut in HDV, then export to MPEG. The difference in the image quality is significant.
#17 |
Yes - when I've upgraded my computer, this is what I expect I'll do. The final render to SD DVD format will probably be no slower than my current machine which takes about 4 hours for a 90 minute avi file using Canopus ProCoder Express. I leave it running over night!
Steam Age Pictures - videos in aid of railway preservation societies. |
#18 |
Analog component works great with a Blackmagic HD card.
it is easier to key than HDV and yields more resolution. But is obviously NOT portable. :(
will griffith producer/editor |
#19 |
#20 |
Your would need to be connected to a MacPro or similar w/fast HD array.
-will
#21 |
Well portability has been solved with the AJA IO-HD Apple ProRes 422 converter. Using a Mac platform such as the a fully furnished Macbook Pro you can take uncompressed HD with the 4:2:2 colorspace at full 1920X1080 resolution and have this awesome machine convert it via ProRes 422 realtime. You'll transfer data that can be handled by Firewire to connect to your laptop and be completely free from the tower. The data rate is almost that of SD video and can be a feasible solution in the future. I know this is something thats making a huge impact on my first HD purchase. What I want to know is if the analog output of the A1 is full uncompressed HD and is beneficial like the Sony HVR-V1's HDMI output. If so, how good is the conversion of the analog signal to a digital signal? Can't wait to hear some results.
#22 |
It will be better than recording to tape, but it will not be as pristine as
the V1U HDMI nor the G1 HDSDI, or H1...etc. etc. It is analog, so there will be an amount of noise that is not present in a digital signal. However.... it is still much more info than HDV, which is good. The new IO will help greatly, but it still is not a portable solution, like say a 4:2:2 Firestore type device which is completely cable, AC, etc. free. (Which I hope is introduced by someone sometime soon). So in conclusion... HDV looks mighty fine from the A1 and the component output looks even better IMO.
#23 |
Would anyone with a G1 please post a grab from the SDI Out vs HDV to tape so we can compare color etc. Has anyone seen this done on any other site? A picture tells a thousand words.
Would also be neat to see this comparison with some movement in the shot to see if there is difference in artifacts. I've been very impressed with Canon's HDV quality and seen very little artifacts/blocks in the shots. In real world use the Canon footage in HDV is pretty incredible. -Jonathan |
#24 | |
#25 |
SDI and analog are virtually the same as far as I can tell. The Kona card has very good converters, and the Canon's DAC ain't half bad, so the net result is basically an indistinguishable difference.
#26 |
Comparing H1 HDSDI to A1 analog here on a Decklink HD
shows more noise on the A1, the AJA card may look a lot better. Regardless....both look great. If anyone wants to see some frames from greenscreen H1 HDSDI capture we just did today to DVCPROHD email me griffithwb msha com the A1 would look very similar
