Display setting to show focal length at DVinfo.net
Old April 15th, 2007, 03:51 AM   #1
Hi:
Is there a way to configure the display to show focal length rather than the zoom bar?
I have noted that the wide angle suffers distortion, straight lines are not straight, so I like to determine minimal zoom for lines to be straight. This is easier with a number rather than the zoom bar.
Thanks, Erik
Erik Norgaard is offline   Reply With Quote
Old April 15th, 2007, 04:03 AM   #2
Hi Erik. You can use the Custom Functions to display the zoom level as a number instead of the bar. This will give you the control you want. Check out the thread below for the procedure.
Richard
http://www.dvinfo.net/conf/showthrea...ustom+function
Richard Hunter is offline   Reply With Quote
Old April 15th, 2007, 06:01 AM   #3
Thanks, got it (sorry for the repost). I had hoped though that it would show zoom as focal length in mm, and coming from 35mm photography, choice of equivalent focal length would be great...
He he, and while messing around I have found you can set which direction the iris, focus and zoom rings turns. I have Nikon SLR and Nikon have it opposite of Canon - neat.
Cheers, Erik
Old April 15th, 2007, 11:14 AM   #4
There's Object Distance Unit Display (OBJ DST UNIT in the menu) which allows a choice between displaying feet or meters. You can always choose whether to have this displayed always or only when the zoom ring is used.
This is not the same as the Zoom Indicator (bars or number) as mentioned before.
Look again in the Custom Function #11 settings.
Bill
*edit* Disregard... I mis-read :-\ Apparently I can't distinguish between zoom & focus when I 1st get out of bed :-|
Last edited by Bill Busby; April 15th, 2007 at 11:19 AM. Reason: brain malfunction
Bill Busby is offline   Reply
