Best Settings For Protecting Higlights at DVinfo.net
Old April 14th, 2007, 09:32 AM   #1
I spend some time today testing out what effects the Setup Level and Master Pedestal controls have on the image with regards to creating or fine-tuning presets to protecting highlights and give the "best" (subjective) possible dynamic range.
The SETUP LEVEL controls the overall exposure curve. Set to "0" blacks are at 2%. Adjusting the SETUP LEVEL up or down shifts the black level by 0.5%. So SETUP LEVEL -4 puts blacks on 0%.
The maximum white level changes depending on the gamma selected.
Normal Gamma with Setup 0 = 109%
Cine 1 Gamma with Setup 0 = 105%
Cine 2 Gamma with Setup 0 = 103%
Normal Gamma with Setup -4 = 107%
Cine 1 Gamma with Setup -4 = 103%
Cine 2 Gamma with Setup -4 = 101%
Obviously this means that using a preset with a SETUP LEVEL of "0" and Normal Gamma gives you the greatest retrievable information in the highlights (with 9% headroom).
If you push the SETUP LEVEL below -4 using Cine Gamma you can end up with whites blowing out before they reach 100%!
The MASTER PED allows you to shift (theoretically) the black level up and down. It actually does shift the whole curve up and down slightly, within the overal curve. If you push MASTER PED down and SETUP LEVEL up then you can crush shadows to the point of losing detail.
Alex
Alex Leith is offline   Reply With Quote
Old April 14th, 2007, 09:55 AM   #2
Disjecta
What's your knee setting? If you turn that to low, you will get a much more graceful transition to blown out whites instead of instant clipping if you are using auto or high
Try my Digital Therapy: http://www.pinelakefilms.com/digital_therapy.html
Films on ExposureRoom: http://exposureroom.com/members/disjecta.aspx/videos/
Steven Dempsey is offline   Reply With Quote
Old April 14th, 2007, 10:12 AM   #3
Sure thing Steven, Knee set to low provides a nicer transition to white.
Now, would you go for setup at 0 to provide the greatest amount of highlight protection, or would you go for setup at -4 to provide true blacks, but less retrievable info in the whites?
Alex
Old April 14th, 2007, 10:14 AM   #4
Disjecta
Personally, I would keep setup at 0. Shifting it downwards takes the vibrancy out of the look for me.
