Anyone using After Effects successfully? at DVinfo.net
Old April 10th, 2007, 10:01 AM   #1
Hi everyone,
I'm having trouble rendering in After Effects. My finished clips alias horribly. I can render out of Final Cut Pro fine.
I'm capturing via Final Cut Pro with it's HDV preset, 24 frames a second. It converts the clips into an uncompressed quicktime. No problems there.
But in after effects 6.5 there is no HDV preset (7.0 has one) When I make a composition out of the clip it gives me the following parameters.
1920x1080
1.33:1 Non-square Pixel Aspect Ratio
frame rate: 23.976
and when I render I don't change the frame rate or size. Nor do I interlace, I render in frames.
My final renders have aliasing problems on all vertical lines within the scene.
Any ideas? ...thanks
Win
Win Edson is offline   Reply With Quote
Old April 10th, 2007, 10:52 AM   #2
After effects
I had the same issue for a while. It makes a big difference how and where you do your conversion.My best results, after a lot of exporting and checking frame on frame results was the following:
-capture with fcp your hdv 24p (DVHSCAP is also great but no log)
-convert to AIC or dvcpro or whatever using compressor (you can batch and it keeps timecode, mpgstreamclip won't)
- use that converted file in after effects (it usually interprets the footage as interlaced, you have to go into interpret footage and change that)
-Render using the same codec (I use aic and make sure to chose the progressive and 24p)
"I'm just videotaping the birds..."
http://www.rbellini.org
Roberto Bellini is offline   Reply With Quote
Old April 10th, 2007, 11:55 AM   #3
sadly ive not used fcp + afx together as im a pc man
BUT
in after effects i always use
1920x1080 SQUARE pixels
24fps
and if the footage is interlaced make sure you select UPPER fields first
Best of luck
Stick Tully is offline   Reply
