Small diameter external mic question at DVinfo.net
Old April 6th, 2007, 04:57 AM   #1
What are folks using to adapt smaller diameter external mics to the clamp on the A1 short of using a different mount?
A few turns of Gaffers tape on the mic barrel to make it thicker?
Some sort of foam padding?
dpalomaki@dspalomaki.com
Old April 6th, 2007, 07:11 AM   #2
Hi Don, gaffer's tape has indeed been suggested in the past, but a more elegant solution involves a trip to your local mega-hardware store for some rubber bushings (there are bound to be some in just the right size).
Old April 6th, 2007, 07:18 AM   #3
Ahhh, perhaps some O-rings...
Old April 6th, 2007, 10:35 AM   #4
Contributor
Or rubber bands.
The mount barely is big enough for my old Sony mic, but I managed to squeeze it down OK.
Old April 10th, 2007, 10:33 AM   #5
a little gaff tape works fine
Stu Minnis is offline   Reply With Quote
Old April 10th, 2007, 08:28 PM   #6
I use a wrap or two of softish foam....maybe helps with isolation a bit more than gaffer tape would. Using a Audio Technica 4051a with the mount.
James Hooey is offline   Reply With Quote
Old April 12th, 2007, 02:13 PM   #7
Don,,
Please take a look at my mic mount. It will allow you to use a rubber band shock mount AND mount a radio receiver, in addition to solving the too small a mic problem. Check it out at www.thej-rod.com
Happy shooting !
Jeff Rhode is offline   Reply
