24F Not Good Enough For Film Transfer At DVFilm? - Page 5 at DVinfo.net
Old March 28th, 2007, 07:28 AM   #61
Originally Posted by Mathieu Ghekiere View Post
I fully agree, that's why I also posted earlier that I was happy that this thread didn't got closed, because it holds valuable information that people later can look up.
It did get locked at one point, but was reopened for Marcus' comments, and the way it progessed after that, including everyone taking a deep breath, is a testament to this community as a whole. This will be great info to have in the search.
Do wish I could change the title though to read "24F IS Good Enough For Film Transfer". Chris? Anyway to do that?
Todd Mattson is offline   Reply With Quote
Old March 28th, 2007, 08:26 AM   #62
Markus, since you're updating the out-dated information about what is or isn't suitable for film transfer at DVFilm: how about the Sony HVR-V1U/E/P progressive format, the 24/25/30 PsF?
Old March 28th, 2007, 08:33 AM   #63
Contributor
It seems to me the only way a meaningful test can be done on this issue is for somebody to shoot something with the Canon camera at 24F, then shoot exactly the same thing from exactly the same position at 60i and send both to DVFilm. Then you can see if the resolution difference makes any difference.
From tape-to-film transfers I've done over the years, the most important things are the quality of the original video and your choice of facility to do the transfer. As I posted earlier, DVFilm did excellent work for me on a project a couple of years ago. It was all standard interlace DVCAM footage with two different cameras, a DSR500 and a DSR250. The 35mm print projected in a theater looked as good as the original video. And, in shooting 24p footage with the XH A1, the resolution in that mode is significantly higher than the DSR500 shooting DVCAM, so it's logical to expect a transfer to look as good or better than even the 2/3" chip camera shooting DVCAM.
One thing I remember from the transfer at DVFilm...they had recommended the titles be put on a separate file at 24p because the end quality would be better (my master was 60i). I didn't do that because there wasn't time, and the end product looked perfectly fine. I'm sure doing it right would have made it look even better, but my point is, with a good facility and good lab, you're going to get a good looking print if your original video is good. My attitude is that I'd rather keep everything progressive all the way even if it involves that slight loss in resolution. Remember that with the Canon system, you're talking about the difference between the Canon at 60i and the Canon at 24p, and its resolution is high enough to begin with in 60i that you can loose a bit with no big problem. But if you chose to shoot 60i and go to film, my experience is to let DVFilm do the conversion rather than doing your own deinterlacing in the computer.
Old March 30th, 2007, 08:49 AM   #64
I just had a project transfered to Dbeta by a fiend that works in a pro editing house in Nashville & we had a long talk on this subject.
Seems that for me 60i is the way to go. Just the fact that if you have a shot you want to slow down, you've got that possibility with all your clips & since I'm working on a new doc, having the footage for "stock" seems better in 60i also.
60i just seems to me to give you more choices as to what you can do with your footage overall.
Chris
Chris Korrow is offline   Reply With Quote
Old March 30th, 2007, 05:08 PM   #65
film vs hdv
this is film trailer the few outdoor shot looks very much like hv20
http://www.camuser.co.kr/cam_vm/VID_...ark_h1080p.wmv
here's hv10 upconverted to 4:2:2
http://www.camuser.co.kr/cam_vm/VID_...2007/03/sd.wmv
Jung Kyu is offline   Reply With Quote
Old May 2nd, 2007, 11:01 PM   #66
Images: 1
Originally Posted by Gary McClurg View Post
I'll have to find the link but there's a trailer callled Man II Man... shot with the A1 and a 35mm adpater... would be nice to have this part of the test to see how much more the image will be soften up using the adapter than not using an adapter..
http://www.stefweb.net/mantoman/Trailer%20TEST%205.wmv
for anyone who's interested. It is, by far, not the best but the best-employed 35mm adapter footage I have seen to date. It is effective, clean and unobtrusive. Most shots have little DOF effect, but the film look is there. Add some more resolution and you'd have a superb 16mm replacement digital video recorder.
BenWinter.com
Ben Winter is offline   Reply With Quote
Old May 2nd, 2007, 11:58 PM   #67
heres a tip...
DONT TELL THEM ITS FRAME MODE
once you're done editing, simply render out as native with no pulldown..
voila problem solved..
Peter Jefferson is offline   Reply With Quote
Old August 27th, 2008, 03:09 AM   #68
Great advice
Originally Posted by Peter Jefferson View Post
heres a tip...
I love that! Will remember it. I guess same apply for those located in PAL world.
Pavel
The fish is the last to know the water.
Pavel Tomanec is offline   Reply
