Footage Galore! - Page 3 at DVinfo.net
Old March 8th, 2007, 02:19 PM   #31
Disjecta
Here's what I use in Premiere Pro 2.0
Don't ask me to explain these settings, I don't have time right now :)
First make sure your timeline is active and then
FILE->EXPORT->ADOBE MEDIA ENCODER
From the drop down menu, choose WINDOWS MEDIA
Use the following settings:
Video -
Allow interlace processing - off
Encoding passes: One
Bitrate Mode: Constant
Frame Width: 1440
Frame Height: 1080
Frame Rate: Same as source
Pixel Aspect Ratio: HD Anamorphic 1080 (1.333)
Bitrate Settings:
Maximum bitrate: 10,000 (you can experiment with these two settings to taste and to get a good size for the file)
Image quality: 100
Advanced Settings:
Decoder Complexity: Auto
Keyframe Interval: 4 seconds
Buffer Size: Default
AUDIO:
Audio Codec: Windows Media Audio 10 Professional
Bitrate Settings:
Encoding passes: Two
Bitrate Mode: Variable Contstrained
Basic Audio Settings:
Audio Format: 128kbps, 48khz, 2 channel bit VBR
Peak Audio Bitrate: 129
Peak Audio Buffer Size: 4
Leave the rest at default.
Try my Digital Therapy: http://www.pinelakefilms.com/digital_therapy.html
Films on ExposureRoom: http://exposureroom.com/members/disjecta.aspx/videos/
Steven Dempsey is offline   Reply With Quote
Old March 10th, 2007, 12:29 PM   #32
Ok cool I'll give that a go, cheers buddy
Giles
Giles Buchanan is offline   Reply With Quote
Old March 28th, 2007, 04:30 PM   #33
Quicktime pro is awesome for web conversion
Marlon Torres is offline   Reply
