#31 |
I must say that when I plug a good Neumann mic in to my A1 it sounds very good. Maybe not as good as it's possible to get but still very good. Matching the mic may be the issue?
:) Mike |
#32 |
Contributor
I use mostly a Sennheiser MKH60 and it sounds great too.
#33 |
sound update - good news and a new wrinkle
After reading everyone's suggestions here, and using my A1 on a few more jobs, I'm now quite comfortable with the sound quality when the Mic Att setting is turned on. Thanks all.
Now there's a new problem. Either I never noticed it before, or it never existed before, but when my shotgun (Rhode) is mounted in the shotgun mic clip I hear siginificant hum coming from the camera motor. It took me quite a while to figure out where the hum was coming from actually, but as soon as I took the shotgun out of the mic clip, the hum was gone. I can recreate the hum by simply touching the microhone to the body of the camera. I know that the rubber gaskets inside the mic mount should dampen those vibrations, and if I simply lay the microphone in the clip but don't tighten the screw, then I don't hear the hum. But as soon as I turn the screw to provide enough tension to keep the mic in place, then I hear the hum again. I have solved this problem by using a shock mount in the hot shoe, but I'd hate to think that my shotgun clip is no good to me any more. Has anyone experienced this? |
#34 |
The mount is a mount only, not a dampener as I found out the hard way. Then again, there are no rubber sprockets to separate the mic from the cam.
I had to use some soft foam tape to mount my mics (K6 ME64/66) and it has helped a bit but the mount itself does nothing to stop any camera noise from being picked up. Does anyone know of any solutions to the on cam mic mount? Such as mounts with proper sized threads and placement of those threads? |
#35 |
#36 |
In the XH-A1, the moment you choose XLR inputs in the audio menu, the built-in mics and the 3.5mm mic socket are switched off, regardless of whether you plug anything into the XLR sockets. However, when the XLR inputs are not selected, the internal mics are live unless you plug something into the 3.5mm mic socket. Having the choice of internal mics or balanced XLR inputs is pretty useful (compared to e.g. Sony FX7/V1 where you have to choose when you buy the camera) but it is an either/or choice per shot.
Steam Age Pictures - videos in aid of railway preservation societies. |
#37 |
As you tighten the screw on the mic mount, it compresses the rubber damping material. The more it is compressed, the less damping it provides, and the more vibration is transmitted to the mic. In general, the best damping performance is provide when the external mic is loosely held by the clamp.
dpalomaki@dspalomaki.com |
#38 | |
#39 | |
Audio test using shotgun and mic mount
This is very true. Last night I performed a test with two different but very common shotgun mics, each screwed firmly in place on the mic mount. In fact, they were very likely screwed in too securely. All the same, I'm going to share my results. I used the Rhode NTG-1 and the Sennheiser MKH 60 (P48). I ran the audio from my XH A1 directly into my computer, so that I could record the camera's audio signal while the camera was 1)recording, 2)in pause, and 3) in power save mode. If you are listening with headphones, you will hear that the Rhode mic picks up much more hum from the camera motor. That being said, I don't know exactly how to interpret the results of this test. I almost always use a shock mount for shotgun mics anyway, and I've recorded lots of audio with my Rhode and I've always been happy with the results. The simplest conclusion I can draw is to follow Don's advice and avoid clamping down too hard on the mic. To hear my results go here: http://www.theclawproductions.com/test/MicMountTest.mov |
#40 |
Microphone positioning is a MUCH more significant factor than the A1's noise floor.
A couple of the posts here suggest that the A1 doesn't record PCM sound. It does - when you are recording SD video - and just as well as other camcorders of its ilk. It's impossible, as someone else mentioned, to tell the difference between PCM and the slightly compressed audio of the HDV format. But it's also true that any compression will be exaccerbated in post by further compression (for broadcast or for the internet). I don't think this is a big deal though - the audio compression of the format certainly won't ever be as apparent to the ears as the video compression of HDV is to the eyes! (Of course, if you were shooting for TV broadcast, you'd probably be filming in SD anyway, so the sound would be PCM in the first place.) I don't think the A1 is particularly noisy when correctly set up. It's probably not advisable to record onto a camcorder for anything intended to be played loud through, say, cinema speakers - but for TV and PC playback, it's not bad at all. The only thing I really dislike about the camera's audio is the peculiar insensitivity of the line inputs, and the counter-intuitive gain pots. |
#41 |
Contributor
I agree--the damn pots are backwards.
#42 | |
Thanks for the tip Paul. |
#43 |
To clarify: when shooting SD the audio is DV standard 16 bit 48 kHz sample rate uncompressed pcm wav, better than CD in theory.
When shooting HDV the audio is compressed to MP2 at about 1:5 ratio. This is the unfortunate side effect of fitting (near) HD data to a miniDV tape. This is the same with all HDV cameras. For critical HDV work use external audio recorder at 16/48 (or 24/48 and convert to 16/48 for edit). About hiss: you have to listen to clean sample to judge the real quality of the audio. Often camera headphone amplifiers are noisy, as are PC based edit systems. Connect the camera to TV and hifi stereo system to hear what the audio on tape is really like. |
#44 |
For Jeff Johnson's reference.
http://www.dvinfo.net/conf/showthread.php?t=89879 provides information on noise levels.
#45 |
hmm
just a question. i am new to the whole video filming thing(just got an XL1 last week), and the processes that are used here. i joined up here in dvinfo.net and have been soaking up as much info about DV filming as i can. when it comes to sound i have a couple questions....
why does anyone attach a mic to a camera? i have been doing Audio recording as far as music for about ten years now. a couple of those years analog and the rest digital recording with Pro Tools and Cubase. granted its two different worlds, and from the sound of it the tolerances of quiet that you need in recording music is different from the tolerances of quiet you need in recording Video. attaching a microphone to something that has any moving mechanical parts whatsoever sounds crazy. even loosely attached. i suppose if that does the job thats cool. just sounds odd. why does everyone record sound to the camera? unless i am wrong when you run all of the sound right to the camera its recorded along with the video. imbedded in with the MPEG4 or on the MiniDV(in my case). i suppose if people are just using one mic on a pole, or attached to a camera, its not much to worry about. but if you are using multiple mics to capture better sound, and perhaps ambient noise, wouldnt it be better to record it to separate tracks on another audio device? that way each microphone track could be altered in post. perhaps one mic track needs a noise gate/limiter because of one instant where the sound redlined, or its too quiet/loud, or needs different compression levels, or really anything. i have never tried syncing audio to video so maybe therein lies the answer why its recorded straight to the camera. but i would imagine avid/protools does a good job of syncing sound. i guess i am used to putting five mics around a room to record a guitar amp and tweaking the sound of all five to get something distinct. all of that nonsense isnt neccessary in the filming. still it would be nice to record serveral digital tracks and have the option of doing whatever you needed to sound later instead of recording two or more mics through a mixer to a camera where you lose track individuality. these are the ramblings of a newbie so if they dont make sense or i am way off on something i apologize now. |
