URGENT! Sony HDR-FX7E PAL footage on a Canon A1? at DVinfo.net
Old February 10th, 2007, 09:05 AM   #1
I have some footage shot with a German bought Sony HDR-FX7E in PAL and I need to capture it with my Canon A1.
It was shot as 1080i/50. Does anybody know if I bought the PAL upgrade for the Canon if it will be able to play this tape?
I have to figure out a soltion asap. Thanks!
www.CodemanStudios.com
Cody Lucido is offline   Reply With Quote
Old February 10th, 2007, 01:25 PM   #2
Assuming you have the NTSC 60i model now, then yes, the PAL 50i upgrade will allow you to play 1080i HDV tapes from Canon or Sony 50i HDV camcorders. However, keep in mind that the upgrade cost is $500. I think it would be more practical and much less expensive for you to simply hire a service to do the capture for you.
Old February 10th, 2007, 01:36 PM   #3
Thanks Chris.
I am attempting to be that service. I must have been delusional, as I thought the conversion was $100.
Cheers!
Old February 10th, 2007, 01:46 PM   #4
Well if you ask me, I think the conversion *should* be $100. But unfortunately it ain't.
Old February 11th, 2007, 02:30 AM   #5
Images: 4
Short answer: most probably not.
Long answer: but maybe a Sony NTSC HDV camcorder would work.
Sony DV camcorders have had the ability to PLAY (not record) both PAL and NTSC tapes since the time of the PC1. Sony never advertised that feature, but it simply works.
I don't know the situation for HDV, but I did the following tests (I have PAL equipment and some DV tapes recorded in NTSC):
-tried a NTSC DV tape in the PAL Sony HC1, it played it perfectly (even indicated "NTSC" on the monitor)
-tried the same NTSC DV tape in the PAL Canon A1, the screen goes black with a red warning "Incorrect tape specification".
I can't do the same test for HDV tapes, because I do not have a NTSC HDV tape, but maybe your solution would be to borrow a Sony camcorder for the transfer. It is worth a try...
Jerome Marot is offline   Reply With Quote
Old February 12th, 2007, 10:58 AM   #6
IIRC, the Sony Z1 will play and record HDV in either 50i or 60i. How much to hire one of them for half a day?
Steam Age Pictures - videos in aid of railway preservation societies.
Mark Fry is offline   Reply
