A1 with Telescope at DVinfo.net
Old January 29th, 2007, 07:57 PM   #1
A1 with Telescope
I have the A1 and a Meade telescope. I want to adapt the two together through the eyepiece of the scope. I tried aiming the A1 into the eye piece, but without a macro function on the A1 lens, I will need to make or find glass that might make this possible. I never was able to get a clear image. Anyone out there have any tricks up their sleeves? I want to get a really close moon picture in HD.
Larry Huntington is offline   Reply With Quote
Old January 29th, 2007, 08:35 PM   #2
Reflector or refractor?
By the way the Canon XH camcorders do in fact have a macro mode. It's built in and automatic. Simply remove the lens hood and zoom out to full wide... bingo, you're in macro mode. You can focus right up to the front of the XL lens.
Your biggest challenge is going to involve how to mount the camcorder to the telescope eyepiece. Not an easy thing to do considering how fast the moon appears to move through the telescope's field of view. I think you're better off using a digital still camera for this purpose; three megapixels will more than equal HD resolution.
Unless your goal is to get moving images... in which case, it's going to be a huge challenge!
Old January 29th, 2007, 10:20 PM   #3
Dslr
Digital SLR is going to be your best bet. It is very common to capture telescopic images with in this manner and many adapters have been specifically created for this purpose.
Best of Luck!
Estebe Verde is offline   Reply With Quote
Old January 29th, 2007, 10:51 PM   #4
"Reflector or refractor?"
Not sure Chris. It's a short, fat telescope with computer control. I actually want to fabricate a mount that will allow the A1 to sit with the telescope and track with it.
I guess a still SLR would be an easy alternative, but with a still image, you can tell- no heat waves- no sense of movement. Plus it just might be cool to try this during the day for nature shots. It's just a little experiment I might be trying. Film maker Ron Fricke has made some amazing things happen with tracking devices and timelapse 70mm cameras, i.e the film "Baraka". That has inspired me to try this telescope experiment.
In the focusing section in the Canon Manual, there is no mention of auto macro. I have not been able to get it to work either. I'll keep trying....
Chris, you have any more tips on using the macro feature? How close can the lense get to an object for macro to kick in?
thanks!
Old January 29th, 2007, 10:59 PM   #5
Macro focus Solved
Chris, I just tried the macro with the hood off and it worked fine. Just held up my cell phone right in front of it and it's in perfect focus. Nice! This is good to know! I think I have that covered now....just adapting the lense to the eye piece will be the challenge.
Old January 29th, 2007, 11:27 PM   #6
Larry, short fat telescopes are almost always reflectors - refractors are like the old time pirate telescopes, where everything done to magnify the image is done with glass lenses - a reflector scope can be short because the light path is "folded" at least once by the use of a concave mirror at the very back of the scope, which acts in place of some of the lens elements. These will usually have their eyepiece closer to the front of the scope, although some scopes (Questar, for example) use ANOTHER mirror centered near the front opening of the scope that gathers the light from the rear mirror and reflects it back through a small hole in the center of the rear mirror (usually called a Schmidt system for its inventor) where the eyepiece is located -
Anyway, on to the mechanical problems of mounting a camera on your scope and still having it track - I think this may be harder than you hoped; when you add the weight of the camera to one end of the scope, it seems to me like it will unbalance things quite a bit. This may cause undue stress (or even failure) of the tracking system.
Not knowing any more about your scope than has been mentioned so far, I could be totally wrong (like, that's never happened before :=) but just thought I'd warn you in case you've not already considered that possibility... Steve
Edited to change convex to concave- sorry... Steve
Steve Leverich is offline   Reply With Quote
Old January 30th, 2007, 12:54 PM   #7
Thanks for the tidbits Steve. I never knew the difference between those 2 types of telescopes.
I agree on the weight issue- the weight of the camera might or will strain the motor on the telescope. Plus, figuring out that computer on the scope is a little daunting. I am going to just try getting the moon moving through the eyepiece without tracking it (for now), escecially now since I figured out the macro focus...thanks to Chris.
Thanks again for all the great info lads!
