Stupid Question (What casette?) at DVinfo.net
Old January 29th, 2007, 01:26 PM   #1
Hi all, sorry for this question. Someone else asked it before but I didn't pay any attention at the time.
Just wondering... Does the A1 use standard miniDV tapes? I know it comes with an HDV tape, but do I have to film everything on those casettes? Or do you only use the HDV tapes for shooting HD. I'm only planning on shooting with SD at the moment (camera arrives soon) so are standard miniDV tapes fine?
And, (assuming I do use miniDV) what are the best tapes to buy in terms of brand? I read panasonic were good (because of lubing or something)...
Cheers,
Giles
Giles Buchanan is offline   Reply With Quote
Old January 29th, 2007, 01:28 PM   #2
Please see the many many threads and posts in the "Long Black Line" forum.
Start here:
http://www.dvinfo.net/conf/showthread.php?t=84130
http://www.dvinfo.net/conf/showthread.php?t=82565
http://www.dvinfo.net/conf/showthread.php?t=80404
Mike
Chapter one, line one. The BH.
Mike Teutsch is offline   Reply With Quote
Old January 30th, 2007, 09:12 PM   #3
HDV vs. SD tapes
The only reference I have found to a "difference' between HDV tapes and SD is about "quality control."
If anyone here knows different, please correct me.
I have used Panasonic "Master" Quality, AY_DVM63MQ, tapes in my DVX-100 for almost 4 years. I have used 100s of these tapes with NO problems. They use a "dry" lube and I chose them because of the dry dusty conditions in AZ. I assumed I would have less gunk build-up in the drive mechanism. I have only ran a cleaning tape 3 times in 4 years and NOT because I had a head problem but just because I got nervous and couldn't believe the head was still clean after so much use.
I plan to use the same tapes in my new XH-A1.
The last box of 50 I bought came from a dealer on Amazon for $5.45 each.
Once you pick a brand you like, stick with it because different manufacturers use different lube compounds and they are not chemically compatible (i.e. will create gunk on your heads).
Edward Randolph is offline   Reply
