Canon Hard Case HC-4200 Information at DVinfo.net
Old January 29th, 2007, 01:08 PM   #1
Hello all,
I just received my XH A1 this past friday... and WOW. That's all I can say.
I purchased a plethora of accessories for it (based on information available on this forum and from CanonUSA.com). Surprisingly, I found little to no information on this forum about the Hard Case HC-4200 from Canon, so I wanted to provide some information.
Being new to the prosumer DV arena, this is my first case for a camcorder, but rest assured, it's pretty awesome.
The HC-4200 seems to be a pretty rugged case from the outside. It has aluminium corners, and the inside is lined with hard foam. There are also 2 pretty solid latches which keep the case closed securely. Inside, you will find a pretty deep case, which allows for the storage of a lot more than just the camera. You can keep your charging accessories, video cables and more with room to spare, but YMMV. The storage area has a moveable divider, so you can organize your accessories as you see fit. Think of this lower portion of the case as being shaped like a tub with a moveable divider. On top of this, Canon provides a flat foam insert that sits on the edges of the tub. This foam insert is perfectly mated to the XH A1/G1's bottom footprint. There are 2 velcro straps that allow you to attach the camera directly to this insert. The advantage to this is that when you remove the camera from the case, the foam insert is attached to the bottom to avoid any nicks, etc. and provides direct access to the storage in the tub. On the lid of the HC-4200, Canon provides two pouches to store extra batteries (very handy). And yes, even with the Sony eyecup (there are other threads that speak specifically about a Sony eyecup attachment that works perfectly with the A1/G1) attached to the XH A1, it fits perfectly (although you have to fold the eyecup onto itself). I doubt though that you could have an outboard microphone attached to the A1/G1 and still have it fit in this case. I would suspect that the outboard microphone would have to be removed in order to properly fit this case. Also, this case, which will likely be heavy once its fully loaded, comes with a padded shoulder strap to ease transportation.
In any event, I am very happy with this case, and I have no doubt that it will fit virtually any airplane overhead storage (puddle-jumpers may be an exception). Heck, it may even fit under your seat if you lay it sideways. I think its well worth the $339 I paid for it to protect my precious A1.
I hope this has been helpful.
-Ken
Ken Sivaraman is offline   Reply With Quote
Old January 29th, 2007, 01:57 PM   #2
where did you buy it from?
Adrian Paul Spiteri is offline   Reply With Quote
Old January 29th, 2007, 01:58 PM   #3
Adrian, we refer all "where to buy" questions to our trusted site sponsors:
http://www.dvinfo.net/sponsors
Ken, thanks for the detailed report... do you have any photos you can share?
Old January 29th, 2007, 02:03 PM   #4
I can't find this case in particular at Dvinfo sponsors. BHphoto and tapeworks don't have them. I would appreciate if you could guide me as a hard case is what I'm after.
Old January 30th, 2007, 05:01 AM   #5
Can you post some pictures of the case with the camera inside please.
Old January 30th, 2007, 07:59 PM   #6
Pictures of the case
Okay folks,
As requested, here are the pix. There are 6 in total, so enjoy!
This is a picture of what the case looks like when first opened:
http://www.x3j.com/images/CaseOpen.jpg
If you were to look straight into the case, this is what you would see:
http://www.x3j.com/images/CaseTop.jpg
You can then remove the camera from the case. Notice, as I mentioned, that there is a piece of foam that attaches to the camera and seperates it from the rest of the storage beneath:
http://www.x3j.com/images/Platform1.jpg
Once the camera is removed from the case, this shows all the storage available:
http://www.x3j.com/images/CaseInside.jpg
As I said, the lid provides room to store two extra batteries:
http://www.x3j.com/images/CaseLid.jpg
Lastly, you can see a picture of what the foam platform attached to the camera looks like side by side with the case, as well as the aluminium corners of the case I spoke about in my original post:
http://www.x3j.com/images/SideBySide.jpg
-Ken
Old January 30th, 2007, 08:03 PM   #7
Not sure if I can say this or not, BUT...
I will let the forum administrators decide whether or not to delete this reply. Since you can't seem to find this case using the forum's approved retailers, try DigitalFotoClub (www.digitalfotoclub.com), which is where I bought mine.
-Ken
Old January 30th, 2007, 08:15 PM   #8
Does that foam platform allow for shoulder shootin'? ;) Coooo
J/K
Bill
Old January 31st, 2007, 09:53 AM   #9
Shoulder Shooting
Bill,
Ya know, I would doubt that it would be comfortable. It is pretty square on all 4 sides. The other thing to mention is that you cannot attach the A1 to the foam platform with the tripod mount attached. I've aleady tried, using the tripod mount from a Libec LS-38(2A). It makes the camera taller, and thus blocks the lid from closing properly.
Just FYI!
-Ken
Old February 9th, 2007, 02:08 PM   #10
Hi Ken,
Could you tell me the weight of the case as it came without any acessories .. ? exactly the way u received it.. so i can calculate shipping for abroad.. plz?
thanks
Ernanio Mandlate is offline   Reply With Quote
Old February 11th, 2007, 03:13 PM   #11
HC4200 Weight
I don't have a scale, so I can't tell you the weight. If I had to guess, I would say that it is about 5 lbs.
Old February 12th, 2007, 01:55 AM   #12
XL1 to XH A1 conversion
Does anyone know if the old case for the XL1/1s/2/H1 (which basically is the same shell as the 4200) be converted for use with the A1? Is it possible to get just the inside parts and reconfigure it?
Insung Hwang is offline   Reply With Quote
Old April 7th, 2007, 10:00 AM   #13
That's pretty much what I'm doing. I just pack other soft gear around the A1. I wouldn't want to fly with it or ship it, but it's adequate.
I'm shopping for another case though, 'cuz I never did like the Canon case for my XL1. Velcro straps, awkward getting to the bottom storage, no padding.
It'll make a nice attic storage case for the old xl1.
Brad Tyrrell is offline   Reply
