XLR and Main Mic at DVinfo.net
Old January 20th, 2007, 09:02 PM   #1
XLR and Main Mic
Been looking at the manual for the A1 in anticipation of it's arrival on Monday and having trouble understanding something. On my XL2 when I shoot, I typically have the main mic on, audio set for 32k and I use channel 3 for a wireless and channel 4 for a 2nd more higher quality shotgun and sometimes for a 2nd wireless.
If what I'm reading is correct, the second that I plug something into the XLR jack on the A1 the main mic is shut off, is that the way it works? Or is there a way to do 4 channels @ 32k?
Miguel
Miguel Lombana
http://www.miguellombana.com & http://www.phoenixhamradio.com
Miguel Lombana is offline   Reply With Quote
Old January 20th, 2007, 09:08 PM   #2
Unfortunately there's no 4-channel audio mode on the XH series camcorders. That's one big advantage that the XL series has over the XH.
Old January 21st, 2007, 04:05 AM   #3
I am able to put in two mono mics right?
Rik van der Kroon is offline   Reply With Quote
Old January 21st, 2007, 05:03 AM   #4
Yep. 2 XLR inputs are supplied.
Jeff Rhode is offline   Reply With Quote
Old January 21st, 2007, 10:25 AM   #5
Chris thanks, is there a way to keep the wireless and shotgun plugged in and use the menu to turn on the XLR's or if it's in it's on... the manual is unclear about that.
Miguel Lombana
Old January 21st, 2007, 10:47 AM   #6
The buttons on the side of the cam would actually do that.
Old January 21st, 2007, 01:53 PM   #7
Incorrect. The buttons on the side of the cam actually do NOT do that.
To switch between the XLR inputs and the built-in stereo mic, open the menu and go to
Audio Setup > XLR Input > On or Off.
Chris Hurd is offline   Reply
