XH G1 HDSDI to Decklink HD Extreme 8bit 4:2:2 test at DVinfo.net
Old December 16th, 2006, 09:56 AM   #1
Here is the file if you are interested.
Kaku Ito is offline   Reply With Quote
Old December 17th, 2006, 10:43 AM   #2
Images: 57
Thanks Kaku. Long download but worth it. I needed something to compare/reference with my own G1 footage. I'm ingesting on the PC side via Xena HS into PPro. But will reserve my final decision until I install and test with the Prospect plugin.
Peter Ferling is offline   Reply With Quote
Old December 18th, 2006, 07:21 PM   #3
Peter,
Glad someone gets use of it. I will find something better to shoot indoor next time. I also did 24f shot at 1080/60i and it looks good, too.
What do people wanna see for limitation of shooting indoor?
Old December 19th, 2006, 11:50 AM   #4
Thank you Kaku. Download completed - but what file type is this?
Michael
Michael Mann is offline   Reply With Quote
Old December 19th, 2006, 12:34 PM   #5
The codec used is the BMD 8 bit codec. You can download it from their website.
www.8cho.com.mx
Rodrigo Gil Medina is offline   Reply With Quote
Old December 19th, 2006, 10:48 PM   #6
Images: 57
Originally Posted by Kaku Ito
Peter,
The footage from the raw capture I have with the Xena as mpeg into PPro, looks comparable to yours. I shot a bunch stuff that's otherwise difficult to see, and can easily pick out details such as finger prints on glasses, fine pitch print (registration and trademarks), and minor imperfections, scratches, etc.
Pulling frame grabs, there's 1/3 more data in images vs. HDV material, (no doubt I want to try this against a green screen and pull a key).
I won't be using HD-SDI all the time, but it sure makes a good arguement for the need of an on-camera capture solution in the future. In the meantime, I've strapped my Boxx workstation to an metal mobile stereo cart, (I have to replace the cheap plastic wheels with metal casters though). It'll do for off-site, local work. I'm getting off topic. When I get Prospect installed, I'll try another test.
Old December 21st, 2006, 08:00 PM   #7
Peter, thanks for your observation and thoughts and thanks Rodrigo for following up about the codec.
I shot some others before I had to return the camera so some more comparison shots between 8bit, 10bit, jpeg and DVCPRO HD will be posted later.
