How to restore the three included Custom Presets? at DVinfo.net
Old December 8th, 2006, 04:06 PM   #1
Preset cycling
Thanks Chris, a big help.
It appears to me that when cycling through the custom presets via the select button, it first goes through the 9 internal and then the 18 on the card - is that correct?
Not knowing this, I replaced a bunch of the internals with the card presets - any way of getting the internal (default shipped) presets back?
Thanks again.
Ron Haley is offline   Reply With Quote
Old December 8th, 2006, 04:41 PM   #2
Hi Ron,
That's 9 in the camera and 20 on the card.
There were three pre-configured presets that came with the camera; they are CP numbers 7, 8 and 9. They're supposed to be write-protected, but if you've inadvertantly changed them, there are a couple of ways to get them back, as described on page 82 of your operator's manual.
You can hard-enter each one using the individual CP details for those presets which are listed on that page, or you can perform a system reset (menu: System Setup: Reset All : Yes) which will clear all customizations that you've made to the camera and also restore those original factory-included presets.
I suppose I could add them to the download library as well for the sake of convenience... will try to get that done soon. Hope this helps,
Chris Hurd is offline   Reply
