Matching LCD to Viewfinder at DVinfo.net
Old December 6th, 2006, 04:09 PM   #1
I can't seem to figure this out, but it has been bugging me quite a bit.
My LCD screen isn't completely accurate in the Color Department. The EVF has more realistic colors and I can't seem to figure out how to remove the magenta tinge on the LCD( they don't match very well). I can change the brightness and color saturation but not change the color appearance. Am I missing something, or am I out of luck?
It is significant enough for others to notice when I point out to them but very bothersome to me, because my white balance always seems a bit off, even if it is right, when using the LCD.
Any help would be greatly appreciated.
Holly Rognan is offline   Reply With Quote
Old December 6th, 2006, 04:13 PM   #2
Contributor
Probably the best thing you can do is adjust it as closely as possible to the color bars and then check it on a flesh tone in good light. There's no way to get a color VF or LCD on these kinds of cameras adjusted with excellent color accuracy. Best you can hope for is a guide so you know you're not shooting at 5500 when you should be at 3200.
Old December 6th, 2006, 04:35 PM   #3
Go Cycle
Lcd Camera Monitors
LCD monitors are really good for composition purposes and very rarely do they show accurate rotation or hues. However, if the color is "way-off' then they will display same throughout the entire picture.
Lou Bruno
Lou Bruno is offline   Reply With Quote
Old December 6th, 2006, 09:07 PM   #4
Well, the lcd isn't indicitave of what really gets recorded, so I guess I will just have to deal with it.
Does anyone else have this problem? I noticed it at first, but didn't realize how far off it was until I started comparing it in the monitor and comparing it to the EVF.
A pretty significant difference to me, but other non-discerning eye's might dismiss it as not a big deal, albeit noticeable.
