is there a Sony Z1/V1-like lens hood that wiill work on my Canon A1? at DVinfo.net
Old November 18th, 2006, 09:32 AM   #1
is there a Sony Z1/V1-like lens hood that wiill work on my Canon A1? (probably will involve drilling a little hole for the AF?)
Herbert Bolander is offline   Reply With Quote
Old November 18th, 2006, 10:30 AM   #2
Contributor
What's wrong with the lens hood that came with it? It's about the same as Sony's. Unless you are looking at that picture of the V1 that has the mattebox attached.
Old November 18th, 2006, 10:35 AM   #3
Maybe he's looking for it because it has a built-in lens cap? It could work if both are the same thread size/bayonet system...
Steven Fokkinga is offline   Reply With Quote
Old November 18th, 2006, 10:39 AM   #4
Contributor
Oh yeah, I forgot about that lens flap. That is kind of nice, actually. Both are bayonet mounts, aren't they? In a perfect world they'd be the same...but.... Is the Z1's lens 72mm? I know the V1 is smaller.
Old November 18th, 2006, 10:50 AM   #5
Yeah... the lens flap is exactly what interests me...
I've had my A1 for less than 24 hours. I've already lost the lens cap this morning. Dropped my grandsons at the airport this morning and tried out my A1 at the airport. When I came home, I realized I don't have the lens cap anymore... not in the bag, not in the truck... darn it... :(
Old November 18th, 2006, 11:08 AM   #6
You can get a replacement from Canon parts & service for about $10 or so. To order, call 1-800-OK-CANON and drill through the menu until you get a live human being. Then you need to cultivate the habit of slipping the lens cap into your pants pocket.
Old November 18th, 2006, 07:17 PM   #7
Habit
Chris is right about the pocket, everytime I take the cap off I put it right into my pocket. Have done this since my XL1s days.
Eric Dyer is offline   Reply With Quote
Old November 18th, 2006, 07:31 PM   #8
Contributor
I always put the lens cap in my left pocket and have been doing that for so many years it's automatic. The only time I ever lost one was inj the winter when I put it in my left coat pocket instead of pants pocket, and it took me awhile to figure that out.
Old November 18th, 2006, 07:46 PM   #9
Put a strip of velcro underneath the lens shade out of sight and put the soft-side of the velcro on the inside of the lens cap. When you remove the lens cap- simply stick it to the underside...no more lost caps.
Steve Nunez-New York City
www.stevenunez.com
Steve Nunez is offline   Reply With Quote
Old November 19th, 2006, 12:41 AM   #10
Don't the Z1 and XH A1 have the same size thread? Might not a Z1 hood fit right on the A1? If it does, I would use it. Just a thought.
Steve Wolla is offline   Reply With Quote
Old November 19th, 2006, 10:59 AM   #11
The XH lens hood is not screwed onto the lens filter mounting threads. It attaches via the bayonet mounting lugs instead.
Old November 19th, 2006, 02:02 PM   #12
The Z1 lens hood is also on a bayonette type fitting - although I wouldn't imagine for a second that they're going to be similar enough to be interchangable...
Alex
Alex Leith is offline   Reply
