Matte Box + AF<>Manual<>AF at DVinfo.net
Old November 14th, 2006, 01:52 AM   #1
Old Boot
Having seen where a matte box fits, could somebody try this out WITH Auto (PUSH) Focus <> Manual Focus? Please?
TIA - Grazie
Old November 15th, 2006, 07:51 AM   #2
Im using a mattebox though all my focus is manual.
Noel Evans is offline   Reply With Quote
Old November 15th, 2006, 08:05 AM   #3
Old Boot
Understood. But CAN you momentarily apply AF? Once applied can you go BACK to MF? I do this with my Manfrotto 521Pro LANC. I'm wishing to know if using a MB does it get in the way of AF?
Old November 15th, 2006, 08:05 AM   #4
I think Grazie is asking for a test, from somebody who has a matte box on their XH (Noel?). It seems that the Push AF button uses the Instant Autofocus feature; at least that's what we've heard. Obviously the I.AF feature is disabled whenever a matte box or other lens attachment blocks that sensor . So the question is, with the I.AF sensor blocked by a matte box, what happens when the Push AF button is pressed while the camera is in Manual Focus mode? My guess is that the Push AF button reverts to Normal AF if the Instant AF is unavailable. Who wants to test this?
Old November 15th, 2006, 08:06 AM   #5
Old Boot
Thank you Chris! My Hero!! Exactly that.
Old November 15th, 2006, 09:06 AM   #6
Images: 32
I think there might be a way to assign a custom button as a toggle for the standard autofocus. That may be the solution for those wanting to use a matte box or wide angle lens. I wonder if there's a way to re-assign the Push AF button.
"Ultimately, the most extraordinary thing, in a frame, is a human being." - Martin Scorsese
Michael Wisniewski is offline   Reply With Quote
Old November 15th, 2006, 11:06 AM   #7
Contributor
Noel, what mattebox are you using?
Old November 17th, 2006, 03:20 PM   #8
To ask the Q again:
If you block the Instant Autofocus sensor (with a mattebox or test it with some tape), what is happening with the Push AF button?
The autofocus is using two sytems:
1) Distance reading with the instant autofocus sensor
2) and then with the second autofocus system.
What is happening if you block the IAF sensor?
What happens when the Push AF button is pressed while the camera is in Manual Focus mode and the IAF sensor is blocked??
Raymond Toussaint is offline   Reply With Quote
Old November 17th, 2006, 04:27 PM   #9
Ill check it out this morning and report back. Im pretty sure though the IAF does not work with a mattbox attached, however the AF does.
Old November 17th, 2006, 04:59 PM   #10
It's established that I.AF does not work with a mattbox attached. The only question is, how does that affect the Push AF button.
Old November 17th, 2006, 10:58 PM   #11
I can verify push AF button works with mattebox. Ill post a 3-4 second clip later... setting up for a lit shot atm.
Old November 20th, 2006, 02:02 PM   #12
So then it is using the 'classic' AF system that remains operative, thanks for now!
