Canon XH batteries / battery thread - Page 5 at DVinfo.net
Old November 15th, 2006, 09:13 PM   #61
Contributor
If you don't have a suction cup, probably a piece of gaffer tape would work, but not quite as well. Best to stick with Canon batteries if possible. I'm guessing the housing on the cheaper batteries may be just a little bit thicker.
Old November 16th, 2006, 07:30 AM   #62
Go Cycle
And longer not allowing the small release button to have enough tension.
Lou Bruno
Lou Bruno is offline   Reply With Quote
Old November 16th, 2006, 03:07 PM   #63
I shook the camera downwards while holding the batery release button. This is with the big Lenmar battery. I am thinking about sanding the case of the battery with fine grit to fix the issue. It seems to slide out easier now after the first time it was stuck.
Larry Huntington is offline   Reply With Quote
Old November 18th, 2006, 09:30 AM   #64
What's the "G" in the A1's battery, BP-950G?
I was too excited when I got my A1 and charged the BP-950G in my old, really old, Canon 910 charger that was sitting my my table. For some reason, it would not reach a full charge in that old thing. I now charge the BP-950G in the new charger that came with the A1 and no problems. :)
Herbert Bolander is offline   Reply With Quote
Old November 18th, 2006, 09:46 AM   #65
Graphite. See http://dvinfo.net/conf/showthread.php?t=68012 (The search function is your friend).
Old November 18th, 2006, 04:04 PM   #66
Herbert,
I'm not sure about the 910, but the paper that comes with the 970G battery says that if you use it with a series 900 charger, it will indicate a full charge when, in reality, it is not. They suggest removing the battery and putting it back in the charger for a full charge.
Bill Doyle is offline   Reply With Quote
Old November 19th, 2006, 10:17 PM   #67
Contributor
Originally Posted by Bill Doyle
Herbert,
It probably is due to the timeout safety circuit in the older one. The new higher capacity pack takes longer to charge, so the timeout kicks in preventing full charge.
Alex Dolgin
Dolgin Engineering
Camera DC Power accessories, Fast 4 position Battery Charger
http://www.dolgin.net
Alex Dolgin is offline   Reply With Quote
Old January 13th, 2007, 01:01 PM   #68
IDX Battery Adapter
Is there an adapter for the Cannon XH-A1 to use the IDX V-Lock 10s batteries. They have worked well with my XL-1 and I would like to use them with my new XH-A1.
Dick Graham is offline   Reply With Quote
Old January 20th, 2007, 04:48 PM   #69
what batteries do you guys find fit best
I heard that the impact batteries are a very tight fit in the A1.
Is the cannon bp 950/970g are only opions?
Chris Sinista is offline   Reply With Quote
Old January 20th, 2007, 06:13 PM   #70
I use the 950/970's they fit perfect, last forever, and cost about the same as the off brand, if you shop around.
Stu Siegal is offline   Reply With Quote
Old January 20th, 2007, 07:27 PM   #71
Just go buy the Canon BP950/970 instead of those other brands since the price is almost the same. Give Scott a call from Tapeworks, since his price is pretty good on the Canon batteries.
Anthony Leong is offline   Reply With Quote
Old January 20th, 2007, 07:55 PM   #72
There have been several reports of third-party clones of the large battery getting stuck in the battery well. That doesn't seem to happen to genuine Canon batts, so I see no reason not to stick with them.
Old January 21st, 2007, 01:08 PM   #73
I have used the Power2000 for a few weeks now without incident. Fits without a problem and holds its charge well. Of course, I've only used it for a few weeks, so I can't comment on how it will work long term.
www.gencofilms.com
Larry Kamerman is offline   Reply With Quote
Old January 21st, 2007, 01:11 PM   #74
I'm using 2 BP-945s as well (listed as working with the xl-h1, along with the 950 so I *think* it's mostly the same) and they're big, but fit perfectly.
Byron Huskey
Rhapsodist Productions
"Film as dream, film as music. No art passes our conscience in the way film does, and goes directly to our feelings, deep down into the dark rooms of our souls." - Ingmar Bergman
Byron Huskey is offline   Reply With Quote
Old January 21st, 2007, 05:17 PM   #75
Contributor
Anthony, the only batteries I can find on Tapeworks' web site are like AA, C--flashlight batteries. B&H is $129 for the BP-950G battery pack. I'm wondering if anybody else is significantly cheaper. That's not bad for a battery that lasts half a day with ease.
Bill Pryor is offline   Reply
