Canon XH batteries / battery thread - Page 3 at DVinfo.net
Old September 15th, 2006, 01:13 PM   #31
I don't think there is a dedicated DC input jack. To power the camera off wall power, you need that dummy battery plate from a CH-910 or DC-920.
If you look closely, there is a small grommet on the battery compartment hatch. I think this is a pass-thru for the cable for the dummy battery plate from the CH-910 or the DC-920. Another clue is on the Japanese page for XH accessories ( http://cweb.canon.jp/cgi-bin/prodv-o..._op.cgi?_XHG1_ ) it says both the CH-910 and DC-920 are compatible with the XH series cameras.
Tim Le is offline   Reply With Quote
Old September 15th, 2006, 01:50 PM   #32
I saw that too and couldn't tell if it was a pass-through grommet or an IR sensor. But since the Japanese web page says those units are compatible, then that's good enough for me. Thanks Tim,
Old September 15th, 2006, 01:56 PM   #33
No problem Chris! I've been staring at these XH photos so much to pass the time waiting for these cameras to arrive, I know every nook and cranny by now :)
Too bad the manuals can't be released ahead of time. That would make for some mighty fine reading.
Old September 26th, 2006, 07:26 PM   #34
You know my Canon A-1 Digital had a battery compartment in the front, on the bottom and the dummy plate fit in there to supply converted power from 110 AC.
TAG
Terry Lyons is offline   Reply With Quote
Old September 26th, 2006, 09:58 PM   #35
So it does take the Ch910!
Alright
Matthew Nayman is offline   Reply With Quote
Old September 26th, 2006, 11:43 PM   #36
Terry, the old Hi-8 format A1 was my first Canon camcorder. Nice to run across somebody who remembers it.
Old September 27th, 2006, 02:13 PM   #37
Yes that was my first Canon video camera also. Boy was I so excited to have that!
TAG
Old September 27th, 2006, 02:43 PM   #38
Contributor
A friend of mine had an A1 back in those days, and I had a BVW300, which as you know only used the 20 or 30 minute mini Betacam tapes. Occasionally somebody would want me to shoot a seminar. If it was a decent job I'd rent a BVW50 deck and second BVW camera, but lots of them were not quality critical for the video. So, I would use a little Hi-8 portable deck we had and could get two hours out of that. Sometimes I'd use the friend's A1 as a reverse angle on the audience. It was always softer, but I got by with it, and the audience cutaways saved me more than once. Sony actually made a 1/2" chip professional Hi-8 camcorder that looked exactly like the UVW100 Betacam camera, but the little A1 looked damn near as good and was a heck of a lot cheaper.
Old September 27th, 2006, 07:00 PM   #39
Boy we are so far off topic now but I can't resist. Bill I think that Sony pro Hi-8 was the EVW-300. The king of all Hi-8 cameras, at least those that weren't dockable. See http://commons.wikimedia.org/wiki/Im...ny_EVW-300.jpg
Old September 27th, 2006, 07:05 PM   #40
BTW, have we determined for certain that the dummy charger plate is actually useable, presumably through a port in the battery compartment lid? It must be so, as I just couldn't imagine having a pro camcorder that could not accept wall power but would be nice confirm it.
Pete Bauer
Old September 27th, 2006, 07:09 PM   #41
I should be able to confirm it for you, with photos, in about 24 to 36 hours from now.
Old September 28th, 2006, 11:25 PM   #42
As promised, here it is: the guess about the access tab on the door is correct (click photo to see big).
By the way, Canon USA has asked me to demo these cams today for a group of college / university video program coordinators (as I do for CUSA and other companies from time to time at various trade shows and other events), so I have access to the A1 and G1 for a short time. So let me know what else I can show you.
Canon XH batteries / battery thread-dcinput.jpg   Canon XH batteries / battery thread-dcinput2.jpg
Old November 10th, 2006, 09:06 AM   #43
XH-A1 battery life?
Just wondering what battery life for the XH-A1 is like in recording mode, both with the standard battery that comes with the camera and any bigger batteries available from Canon. Also, is there an indicator somewhere to estimate battery life remaining, and if so where and in what form?
Old November 10th, 2006, 11:53 AM   #44
An energy hog is the best description I can give you. The battery that came with gives me about 2 hours or continuous operation. That might be because I use the flip out LCD over the eyepiece.
I just ordered a BP970 that is supposed to give 6.7 -7.5 hours of life. We shall see.
www.CodemanStudios.com
Cody Lucido is offline   Reply With Quote
Old November 10th, 2006, 06:06 PM   #45
Heh this is one thing I need to be a bit more aware of, I have not stopped for a second to check battery times and its pretty important that I know. I have the 970. An hour use here and there hasnt seen the bar go down at all.
Ill keep a closer eye on it in future. I am using the lock function a lot so it saves me power.
Noel Evans is offline   Reply
