#301 |
My guess is that the battery is the same size as the BP 950 and when you place it over their plate it works out to be the same size like the BP 970. and you slide it in like the Bp 970. But again, I'm only guessing.
Maybe I'm wrong, it has a Capacity 7000 mAh , so that can't be right. the BP 950 has only 5200 mAh and the BP 970 has 7200 mAh. I don't think the plate fit the size of 200 mAh in mass size of the battery.
Website: http://www.Motiononcanvas.com Camera Operator/ Video Editor in Singapore. https://new.cinematographer.org.au/m...713/david-chia |
#302 |
I am working with electric RC Planes and cars. They needs currents up to 140A and due to this has every battery much harder life as a camera battery. Here is abolutelly necesarry to use computer measurement technology for charging and balancing batteries and cells. To build a competitive battery pack, you need hundreed of cells to select 10 cells with optimal parameters for a pack.
You can buy 6cells for a battery pack for 30 Euro or 6 cells from the same brand and type for 250 Euro. All cells looks absolutly identical - but the 6 one for 250 Euro are measured as cells with lovest resistance and highest Voltage. They are pushed and matched and you win the competition, because your car can push and accelerate harder and for a longer time. These are many options how to make a camera battery cheaper. But to be really sure to buy quality - you have to buy Canon batteries - even with extra payment for Canon logo. |
#303 | |
Waiting for renders gives me the opportunity to be a googlelite! Found this :-\ http://www.series7battery.com/ |
#304 |
Wow, doesn't it make the XHA1 even heavier in the front being what it is already. I guess when you add the Wd72 wide angle lens, the thing is nose diving...
Website: http://www.Motiononcanvas.com Camera Operator/ Video Editor in Singapore. https://new.cinematographer.org.au/m...713/david-chia Last edited by David Chia; January 18th, 2008 at 06:08 AM. |
#305 |
Woah! I had no idea that thing connected ontop of the hot shoe like that, or externally from the battery compartment, where I thought it would go, since it's, you know...a battery. This is not practical for me at all. I'm really glad you posted that link Bill...
#306 |
For having a 2006 copyright notice, the Series7 web site is pretty lame as far as providing information about their products; e.g., no user manuals, no FAQ, etc.
dpalomaki@dspalomaki.com |
#307 |
Battery protector
Is there a convention for which way to fit the cover on charged and discharged camera batteries? Which is the colour (blue or grey) which should show through the slot for each?
#308 |
if you read the manual it states that blue is charged and grey is empty, but it is total up to you. I have them this way so that I know which is which when I have a long shoot, especially weddings...
#309 | |
Incidently I use the PDF manual much more than the paper one because I can find things a lot quicker, but in this case I didn't look at all. |
#310 |
#311 | |
#312 |
#313 |
Hallo Thomas
If you're looking for a good and cheap solution: Look here i use 2 of them for a year no problems. http://www.saake-shop.nl/products/Ca...2F+BP-941.html
Canon XH-a1 user & Edius NX Canopus |
#314 | |
#315 |
any update on Impact battery users?? It's either two of these, or one from Canon :(
