Canon XH batteries / battery thread - Page 16 at DVinfo.net
Old June 19th, 2007, 06:27 AM   #226
The Lenmar LIC950G fits, is rated 5200 mAh.
I do NOT know if the LIC970G fits (rated 7000mAh), but Lenmar lists it as fitting.
dpalomaki@dspalomaki.com
Old June 19th, 2007, 07:26 AM   #227
I have bought the LIC970G at 79.95$ and fits perfectly and pull out with internal springs without problems. Recommended
Cesare Improta is offline   Reply With Quote
Old July 1st, 2007, 01:26 PM   #228
Getting the cheaper batteries thread...
I was wondering about Series7 Li+ and Varizoom batteries. They're being sold side by side with the Canon BP series batteries.
I notice that they're significantly cheaper (approx 99USD vs. !66USD for Canon BP-970 units) and was wondering if they even fit properly in an A1/G1 series camcorder, much less how they hold up.
Anyone had good luck with these batteries? Or should I stick with the Canon batts?
Most of my experience has been with Anton Bauer, Frezzi, Sony V-mount, and very few off brand battery kits that usually run on the Gold Mount system. I'm lost on all the smaller batteries. These names don't jive with me.
Alex Lucas is offline   Reply With Quote
Old July 1st, 2007, 01:40 PM   #229
stick with the canon ones. they live longer and run longer than the others.
i'm still using the battery that came with my first xl1-s many years ago with the a1.
Eric Weiss is offline   Reply With Quote
Old July 1st, 2007, 02:26 PM   #230
http://www.antonbauer.com/elipz_line.htm
short that,
I still have my Canon Xl-1s batteries and use them also
Salah Baker is offline   Reply With Quote
Old July 2nd, 2007, 05:25 AM   #231
there are reports of third party battries getting stuck in the A1 battery housing. I also have my XL1 battries.
David Chia is offline   Reply With Quote
Old July 2nd, 2007, 07:17 AM   #232
The third party batteries that are a too-tight fit include some (but not all) of the Lenmar LIC941. The Lenmar LIC950G fit fine. If considering a third party battery, check with other users first, or try a sample before you buy.
Old July 2nd, 2007, 09:24 AM   #233
I will NEVER use third-party batteries after seeing the remains of a friends camera bag a few months ago. The Domke bag contained 2 Canon 5D cameras and 3 lenses(total value of contents was about £7500/$us15,000) Both bodies had booster packs on with third party batteries(Hague I think?) and one of them went into meltdown,completley destroying everything in the bag with melting plastic.
Norwich Union,his insurance company, had all the gear sent to a specialist to see if any of the gear was salvagable and on inspection it was discovered that the camera was using none Canon batteries. Norwich Union refused to pay-out refering to the section in the manual where it basically says not to use any battery other than Canon.
Lesson learnt?!!
Canon XH-A1,SGPRO flip,Apple imac,FCExpress
http://www.pbase.com/philkneen
Phil Kay is offline   Reply With Quote
Old July 2nd, 2007, 02:43 PM   #234
2 years with my HI/Power 5 hour battery from www.ebatts.com for my XL1s. I use my canon battery as a backup...I haven't needed to use it much at all in 2 years. I'll be buying another 5 hour battery to increase my record time up to 11 full hours. I am a happy customer perfectly willing to recommend these batteries to anyone who needs one.
Web Youtube Facebook
Cole McDonald is offline   Reply With Quote
Old July 13th, 2007, 11:14 PM   #235
Will 7.2V Battery hurt A1?
The original Battery BP-950G is 7.4V, now I got 2 spare OEM batteries with 7.2V, will that do any harm to the camera? Thx.....
Juni Zhao is offline   Reply With Quote
Old July 14th, 2007, 03:48 AM   #236
Do you want to really risk your investment on some OEM batteries? It might work but canon batteries are pretty cheap. You don't want to mess up a multi thousand dollar camera on a $20 battery do you?
Canon XHA1, SGpro,Flip,FF, RR Mattebox, Nebtek V-R70p-HDA with Canon, Nikkor Primes 24mm f2.8, 28mm f2.8, 35mm f2.0, 50mm f1.4, 85mm f1.4, 105mm f1.8, 135mm f2.0, and 300mm f4.0.
Cary Lee is offline   Reply With Quote
Old July 14th, 2007, 07:02 AM   #237
I have a long shoot this afternoon till late night, so I went out hunting for additional batteries last night. I definitely would have bought canon battery if I could, but time pressed. The only retail store that had the OEM was Batteries Plus. I think I am gonna return them later. Hope they wont hurt the camera this time.
Old July 14th, 2007, 07:13 AM   #238
most devices have some level of tolerance for varying voltages. .2V should be fine.
Henry Cho is offline   Reply With Quote
Old July 14th, 2007, 08:06 AM   #239
We've tried a number of non original batteries in our Sony cameras. Some are great and some are not so good and some don't work in certain models but never heard of a battery damaging a camera. When it comes to Li-Ion batteries the exact voltage is not that exact. From fully charged to discharged the voltage has a quite large range so the camera's internals has to be able to cope and 0.2V less is going to have no impact.
However, new Li-Ion batteries can take 3 full cycles to reach full capacity, so your new battery may not perform too well on its first day out.
The only drama we've ever had with a Li-Ion battery was an original Sony one, stopped working and then a few weeks later caught fire just sitting on the shelf. Treat all Li-Ion batteries with due caution, it's a rare event that one goes off but I'd hate to have had this happen when the battery was inside a kit bag.
Old July 14th, 2007, 08:50 AM   #240
Bob, thank you for your input. I think the only possibility for a battery to hurt a camera is power surge. From what you said it seems that its unlikely to get surge from a battery. Thank you all guys......
