Canon unveils the XHG1 and XHA1 - Page 7 at DVinfo.net
Old July 26th, 2006, 11:42 AM   #91
Originally Posted by Kevin Shaw
Lorinda: it has a 20X zoom range going from "pretty darn wide" to "more than you'll usually need telephoto". Better than anything else in its class as far as I can tell.
That the one big gripe I have with the FX1, in order to shoot decent wildlife, you need to put on an extender, and there isn't a lot of good stuff out there yet...
Chris J. Barcellos
Old July 26th, 2006, 11:44 AM   #92
Originally Posted by Simon Wyndham
Maybe its already fitted with a neon glow in that circular side bit thingy.
That would be really cool if it was! That would most definitely add to its appeal...
Gabriel Yeager is offline   Reply With Quote
Old July 26th, 2006, 11:46 AM   #93
Originally Posted by Peter Ferling
The smaller size and weight will go easy on my back. A drawback to working with the XL1s. (It's not a true shoulder cam, and required a three-point rig and a wide stance).
These are a bit heavier that FX1 at 2000 plus grams. With nearly the same form factor, I am betting you will have still be dealing with a weight issue and balance, much the same as with the FX1.
Chris J. Barcellos
Old July 26th, 2006, 11:47 AM   #94
If I recall correctly from testing the XL-H1, the side thingy may have some lights in it so you can read the dial and display in the dark. This should be one very sweet camera... why the heck didn't they ship it last year?!?
Old July 26th, 2006, 11:48 AM   #95
Originally Posted by James Klatt
How about the weight of these puppies? I am curious to see if I'd be able to use my merlin steadicam.
Someone quoted 2100 to 2200 grams depending on model My conversion says over 4.5 lbs.
Chris J. Barcellos
Old July 26th, 2006, 11:51 AM   #96
Man! Thats awesome! Now I don't know what camera I should get! I was thinking of going for a gl1 or 2, but now I don't know!
Old July 26th, 2006, 11:52 AM   #97
I wonder if Panasonic would ever decide to put a 20X zoom lens on the successor of the HVX200.
I also wonder how Sony would have reacted if Canon were to release the 4000 dollar XH A1 right now.
Paulo Teixeira is offline   Reply With Quote
Old July 26th, 2006, 11:57 AM   #98
Thanks, Kevin. I need to just be patient and have a look. It's easy to get caught up in the excitement! :)
Speaking of that, Gabriel and James, babies and puppies cost $3999 and $6999, and weigh 4.98 and 5.14 lbs. ;) If you check back on the links provided, there's a ton of info for us! I got a kick out of your enthusiasm, though!
Lorinda
Old July 26th, 2006, 12:00 PM   #99
Images: 57
I was comparing with the Xl1s, it's forward heavy and awkward (I could feel it pulling forward. When I rented a GL1, it was more comfortable), and one of the reasons I was looking at the Z1U. I think the XHA1 would do nicely on a rig.
Pete Ferling http://ferling.net It's never a mistake if you learn something new from it.
Peter Ferling is offline   Reply With Quote
Old July 26th, 2006, 12:05 PM   #100
Ahh! Thank you! I don't think I'll be able to afford that after all... :( But I'll try as hard as I can!
Old July 26th, 2006, 12:10 PM   #101
Just look at it this way. If we hadn't bought those FX1s and Z1s in such great numbers, Canon wouldn't have made these moves. Sony, what's next ? HDV harddrive recording with dockable drive ??
Chris J. Barcellos
Old July 26th, 2006, 12:11 PM   #102
Images: 1
All of the XL series cameras, from the XL1 to XLH1 have a back light that can be turned on to see the LCD in darkness. Push the button, you get about 3 seconds...hold the button for a few seconds and it stays on until you turn it off again.
The only difference that I'm aware of, and Pete Bauer can help is that the XLH1 has a blue backlight while the XL2 and previous models had white backlighting.
-gb-
Old July 26th, 2006, 12:15 PM   #103
MPS Digital Studios
USA site:
http://www.usa.canon.com/consumer/co...&modelid=14057
and
http://www.usa.canon.com/consumer/co...&modelid=14061
heath
My Final Cut Pro X blog
Old July 26th, 2006, 12:15 PM   #104
-gb-
I sure hope that the XH G1/A1 has a blue back light! That would be a great color blend!
Old July 26th, 2006, 12:16 PM   #105
Greg, I have an XL1s and if I'm correct, I think it has blue backlight too. Well, a kind of blue green blacklight.
Not that this is on topic :-)
Mathieu Ghekiere is offline   Reply
