XH A1s and Ninja is anyone doing it at DVinfo.net
Old August 28th, 2013, 10:06 PM   #1
Hi guys
I have an XH-A1s and an Atomos Ninja ... but for the life of me I just can't get them to talk to each other.
I really wish the XH-A1 had a HDMI port, it would make life so much easier.
I have a few other cameras but nothing with the long 20x zoom lens which is wonderful for capturing sporting events.
PS: I really hate tape .... can anyone help ... is anyone using a Ninja with the canon ...???
PPS: I've tried a couple of Component to HDMI converters without success. I cannot get consistant smooth video from them.
Last edited by Richard Tatti; August 28th, 2013 at 10:17 PM. Reason: forgot something
Richard Tatti is offline   Reply With Quote
Old August 29th, 2013, 08:12 AM   #2
Re: XH A1s and Ninja is anyone doing it
Hi Richard, had you thought about the datavideo DN60 its still only HDV but I believe it works ok.(not used it myself) or were you wanting to avoid HDV compression?
best wishes john
john estcourt
www.amourweddingvideos.co.uk
John Estcourt is offline   Reply With Quote
Old August 30th, 2013, 12:24 AM   #3
Thanks for the reply John.
I already have a Ninja which works really well with other cameras ...eg, Canon HV30, Panasonic Ac90 .. but they both have HDMI out. I love the XH-A1 and it's excellent for sports. It's just the conversion from Component to HDMI that seems so difficult to get right.
I don't want to spend upwards of $1000 on a Blackmajic converter but it seems the cheaper ones just don't do the job very well.
Also, the DN60 isn't a cheap option either.
Old October 25th, 2013, 07:55 PM   #4
This is an easy modification. I have bought a conponent to HDMI converter on ebay attached it to a bracket 1 device with a 5 volt usb power supply and now you have a mobile hard disc 422 color space recorder. you should pay from $24-$40 dollars for a HDMI converter. You will have to use HDMI version 1.3 and above. This layout will work on any conponent out camera. I use it also on a Canon XH-A1, Sony FX1 and a Z1U.
Roger Evans is offline   Reply With Quote
Old October 28th, 2013, 05:51 AM   #5
Which converter did you get?
dpalomaki@dspalomaki.com
Old December 7th, 2013, 06:03 AM   #6
I bought the Etekcity 04-LKV354-Etek for about $37 -- and then a 5 volt battery (power supply) about $10, and a usb to 5 volt barrel power cable (for the HDMI converter), about $3.
Its described as HDMI 1.3
The converter and battery together weight about 1.5 lbs.
The XHA1 looks real good so far on my 47" monitor -- but I'm still waiting to get the Ninja -- so judge this post accordingly.
The visual tests I've made are based on the XHA1 component out to the HDMI converter -- and then to the HDMI in of a 47" monitor.
I'm hesitating to get the Ninja because I expect an updated Ninja w/a sharper screen to be announced in April at NAB -- and because I'm short of funds ...
Cyber Monday 2013 Deals in USA? Etekcity 04-LKV354-Etek BUY ONLINE
Pyro AV PVC-988 Video Device - Newegg.com
Amazon.com: Kanex Pro HDRGBRL HDMI to Component with Audio Converter: Electronics
Barry Richard is offline   Reply
