tapeless xha1 at DVinfo.net
Old March 21st, 2013, 04:39 PM   #1
tapeless xha1
You can say that i am an advanced newbie so excuse me if this seems obvious to others. I have a six year old xha1 that i truly enjoy working with. thought about going tapeless with an fs-cf pro but when i called the guy at B&H he told me I would still have to run tape with it. Why?
Arnold Courtier is offline   Reply With Quote
Old March 21st, 2013, 05:27 PM   #2
Re: tapeless xha1
Hi Arnold,
Welcome to DVi. I'm not sure about the FS-CF Pro but we had a discussion about another FireStore, the FS H200, and our members confirmed that you did NOT have to roll tape. The link to that thread is:
http://www.dvinfo.net/forum/focus-en...ml#post1534730
You might poke around in that forum (FireStore) and find out some more info. Hope this helps,
Old March 21st, 2013, 06:16 PM   #3
Re: tapeless xha1
Thanks Chris. I knew it would be on here just a little behind the times
Old March 21st, 2013, 06:27 PM   #4
Re: tapeless xha1
I recently bought a refurbished Datavideo DN-60 from Adorama and it works fine without tape. It's possible to record to tape at the same time, but since the Firewire port on my PC doesn't work and I'm too lazy to replace it, I go without tape when I use it.
Phil Murray is offline   Reply With Quote
Old March 22nd, 2013, 11:20 AM   #5
Re: tapeless xha1
Same story here - I was able to use the firestore with or without tape. I chose 'with' so I had a redundant backup, just in case. Usefully, even if you run tape as well, when the tape ends the firestore carries on. Great for conferences etc.
Ian Stark is offline   Reply With Quote
Old March 27th, 2013, 08:01 PM   #6
Re: tapeless xha1
I recently got an Atomos Ninja and just yesterday got a component to HDMI converter from Amazon that lets me run line out from my XHA1 component out using Canon's cable into the adapter and then into the HDMI port of the Ninja. Works like a charm! The cable (I don't have the part number with me) was $35 and the component to HDMI adapter was just under $50, both from Amazon. Even after the cost of the cable, adapter and a like new Ninja I have an excellent tapeless capture now for under $400! I figure it will give me a few more years of use out of my epic XHA1.
Good luck!
Jim Jordan is offline   Reply With Quote
Old May 5th, 2013, 12:36 PM   #7
Re: tapeless xha1
<<I recently got an Atomos Ninja and just yesterday got a component to HDMI converter from Amazon>> Which converter did you buy, Jim? And did the converter you chose also carry audio? Thx ~ TW
Rule #1: Don't sweat the small stuff. Rule #2: It's ALL small stuff!
Terry Wall is offline   Reply
