#16 |
Re: Xh A1 Tape eject issues
Jeremy,
Curious -- what did that list of fixes cost you? --Mike |
#17 |
$420 fixed and shipped to my door.
#18 |
wow! That's expensive. I have an issue with one of my XHA1's but I knowingly traded for the camera. Like your camera, it has a broken on board mic. It's not a big deal for me because I use a RODE mic with the unit. I'm curious to know if they gave an actual cost breakdown. More specifically, did they say what the cost is to repair the mic?
#19 |
They didn't give me a break down of each part...just a total part cost.
I received the camera today from Canon...so nice. So so nice. |
#20 |
Congratulations! Given all the things they fixed, it sounds like a bargain. The XHA1 is a wonderful camera for the 20x zoom and high resolution image it obtains with CCD sensors at a reasonable price.
#21 | |
Others will be interested to know if it's still available. Thanks. Cheers.
Drink more tap water. On admission at Sydney hospitals more than 5% of day patients are de-hydrated. |
#22 |
Let me grab my slip quick..
Yep, they replaced it. "Cover Ass'y, Handle: DY1-9032-000 : QTY 1" Make sure you request it though. If it wasn't for the sticky, I would not have known about it. |
#23 |
"Mic glued to unit" listed in your estimate probably means the previous owner broke the 'on camera' mic off the A1 and tried to repair it by glueing it
back in place. There's a sticky up top about that and Canon repairing it means that now, you shouldn't get any noise from camera vibration in your audio when you use that mic. ---------------------------------------------------------- "Cover Ass'y, Handle: DY1-9032-000 : QTY 1" "QTY 1." there are two and from memory, it was the handle (or handgrip) closest to the lens that wasn't strong enough and breaking off some folks A1 cams. If you got a total cost on your invoice, are you sure Canon fitted the new 'handle' as their advertised *free* replacement part? Did they tell you that over the phone? Cheers.
#24 |
Meh...I assumed. The total part cost was 130 for everything. I should've asked them when I was chatting on the phone.
#25 |
Don't worry about it mate, press on with your new A1.
The next thing I'd suggest, is to check out the 'free' custom presets up top. Are you up for that already? :) Cheers.
#26 |
I tried to download the custom settings but I have having issues. Are these broken files now since they are a few years old?
#27 |
I don't know but they should be Ok .. read through the download instructions up top, start at post 17.
To save you some time, you might try VIVIDRGB I found it to be very good. You can install it manually but be careful it's easy to enter wrong values, check post 78 for its values. Cheers.
#28 |
It's probably been about 6 months since I downloaded the Canon Presets but when I did, there didn't seem to be a problem with them at the time. Now that being said, honestly, I haven't used them. I typically white balance and make all of the necessary on camera manual adjustments. This is a part of my camera that I really need to get into. I just don't have enough confidence in my understanding of all of the settings and how they influence on another.
