Setting's to Make the Blue's and Red's pop at DVinfo.net
Old October 24th, 2011, 08:45 PM   #1
I am shooting three football games this weekend and would like to get some "pop" out of my camera footage and I do not want to have to adjust it in post. Do you have any good setting's that I can use?
Guy Godwin is offline   Reply With Quote
Old October 25th, 2011, 02:47 AM   #2
Re: Setting's to Make the Blue's and Red's pop
I use Vivid RGB in the field:
http://www.dvinfo.net/forum/canon-xh...tml#post912806
Bill Watson is offline   Reply With Quote
Old October 25th, 2011, 07:52 AM   #3
Hi Guy,
You can use the Panalook2 I think you'll be happy with it.
http://www.dvinfo.net/forum/canon-xh...y-copy-15.html
Canon XHA1, Brevis 35mm, Manfrotto 028,501,Vegas Pro 10e
Matthew Amirkhani is offline   Reply With Quote
Old October 25th, 2011, 02:28 PM   #4
Are there any examples or stills with these presets?
Old October 25th, 2011, 06:57 PM   #5
Use the link that I posted for you and do your search. I am sure you'll come up with some samples.
Old October 25th, 2011, 10:44 PM   #6
Why not download those two presets, go outside and shoot a bit of footage on both, then come back inside and compare them on your tv screen?
Or, better still, hook the camera up to your tv, aim the camera out the window and switch between the presets and get a realtime comparison?
Old October 25th, 2011, 11:43 PM   #7
I use VividRGB mostly but Panalook2 is good too. After you've used them for a while you get to know what each is good for.
The key is getting the right white balance every time you change scenes. I've been using ExpoDisc for a couple years, you just can't beat it for mixed lighting sources which the camera WB never seemed to get right.
http://www.bhphotovideo.com/c/product/358073-REG/ExpoImaging_EXPOD72_ExpoDisc_72mm_Digital_White.html
Avoid the cheap Ebay copies at all costs.
Cheers.
Drink more tap water. On admission at Sydney hospitals more than 5% of day patients are de-hydrated.
Old October 28th, 2011, 06:29 PM   #8
I'm trying...I can't seem to get my camera to recognize the preset on the SD card.
Old October 28th, 2011, 07:01 PM   #9
Guy,
This is what you do.
Open a folder named PRESET in Capital letters.
Copy and past the present into the folder.
Put it on a SD card and insert it into the slot in camer and it will work.
Good Luck!
Old October 28th, 2011, 07:05 PM   #10
I assume I have to transfere it into the camera. When I get to the SD to Camera icon is not whited out. It acts as if it is not accessable.
Old October 28th, 2011, 08:04 PM   #11
You can leave it on the SD card and use the presets of that from XHA1.
Old October 28th, 2011, 08:20 PM   #12
So can i have more than one preset in that folder or just one? Also, will it pull up the name PANALOOK2 in the menu?
Old October 28th, 2011, 08:25 PM   #13
You can have 9 in total.
Old October 28th, 2011, 08:28 PM   #14
Go through this tread and read as much as you can you will find all the answers that you are looking for.
http://www.dvinfo.net/forum/canon-xh...rary-copy.html
Good Luck!
Old October 28th, 2011, 08:56 PM   #15
I did not read all that but. I did realize you have to change the name of the .cpf to PRESET01 or what ever number you want.
