Automatic Image Stabilization at DVinfo.net
Old May 11th, 2011, 08:11 AM   #1
I frequently read about turning off the Automatic Image Stabilization when using a tripod. Whats the benefit of this?
Kevin Lewis is offline   Reply With Quote
Old May 11th, 2011, 10:08 AM   #2
Re: Automatic Image Stabilization
Kevin:
I once noticed when moving the camera very quickly on the tripod and then allowing it to focus on my subject -- a couple of seconds later the image on the screen would move to the left or right.
This occurred continuously while filming in a live situation and switching from camera to camera -- Camera movement on the tripod would have to be fast/quick for this to occur.
I think I posted this experience/problem on a forum, asking for help with this perplexing issue -- the response I got was to turn off automatic image stabilization -- it worked.
Just my two cents, you may certainly never encounter such issues depending on how you film and move the camera.
Alex Lafkovici is offline   Reply With Quote
Old May 11th, 2011, 10:09 AM   #3
If your camcorder is on a tripod, it is unlikely that it is in need of image stabilization ... but any camcorder movement that you introduce, say a gentle creep pan, will be resisted by the stabilization system and so fight your intention. Typically, the system then recognizes you don't want that movement stabilized and releases it -- then tries again, then releases, repeat ... The result is a jerky pan, when you've done everything sensible to accomplish a smooth one. Except remember to turn off the stabilization ...
Cheers,
GB
R Geoff Baker is offline   Reply
