Resetting of White Balance at DVinfo.net
Old May 19th, 2010, 04:03 PM   #1
Hi,
I got a problem which I cant solve and hope someone can help.
I've prreviously set the White Balancing ordinary by pressing the
White Balance buttom.
Now I cant do it anymore, when I press it, the lightbulb blinks constantly
with an ' 0+/- ' to the right of it. It somehow does not set the white balance
at all.
Cant anyone help how to get rid of the ' o+/- ' blinking thing.
Many thanks in advance.
Henrik Joensen is offline   Reply With Quote
Old May 19th, 2010, 06:58 PM   #2
Hmm? I don't know if it will help at all but you might try re-stetting the camera to factory settings.
Danny Winn is offline   Reply With Quote
Old May 20th, 2010, 04:59 AM   #3
Hi
You probably have the WB switch set to "Pre". In this setting you then can chose between Outdoor, Indoor or turn in any Kelvin WB temp between 2800-12000. The choises Outdoor/Indoor/K is made by the small selector underneath the handle.
If WB-switch in "Pre" and in Outdoor and Indoor setting, the WB-button works a little different compared to if the WB-switch is set to A or B. If you are in "Pre" with Indoor/Outdoor selected, pressing and holding the WB-switch you are able to fine adjust the pre-selected colour temp range by the numbers -9 to +9 by turning the shutter dial.
My guess is that your WB will function as you are used to if you put the WB-switch to either A or B.
Regards,
/Bo
Bo Sundvall is offline   Reply
