Xh-a1 Bnc output at DVinfo.net
Old March 16th, 2010, 06:48 PM   #1
Xh-a1 Bnc output
Hello all,
So I just acquired a steadicam pilot from work and am familiarizing myself with it. I successfully hooked up one of my studios xha1's to the pilot monitor without issue however when I try with my own xha1 I can't get any picture from the bnc, is there a hidden setting in the menu pertaining to the bnc output? I can't seem to find it if there is. I'm hoping my output isn't fried but that could be the case. I've had the camera for about three years now and I know the ins and outs of this camera pretty well however this is the first time I've ever tried to use the bnc connector.
Jaron Tauch is offline   Reply With Quote
Old March 16th, 2010, 07:48 PM   #2
Hi Jaron,
There is a switch right next to the composite out on the back your xha1. AV1 & AV2, switch it to AV2 for BNC out. Sadly you cannot use both the composite and bnc at the same time.
-Aaron
Aaron Almquist is offline   Reply With Quote
Old March 16th, 2010, 08:03 PM   #3
Nice! Thank you Aaron, can't believe I missed that...
Old October 5th, 2010, 10:52 AM   #4
What kind of signal is BNC XHA1 output?
Hello:
I don´t know if the BNC output signal of XHA1 is only Standard definition or support HD 1080i like component output.
Thank you.
Josué Manzano
Josue Manzano is offline   Reply With Quote
Old October 8th, 2010, 05:53 PM   #5
the BNC output is a composite signal only
Bill Busby is offline   Reply
