Colors out of wacked. at DVinfo.net
Old December 29th, 2009, 09:43 AM   #1
Hello All,
Please help me with an answer to my frustration.
Last week I was filming a school play, I noticed later than everytime they cloced and opened the curtain for the first 10 seconds or so the colors were were wacked and two saturated and later everything was good. I was filming in 60i HDV and used the lowlight preset I should also should mention that the AWB was on.
Matthew
Canon XHA1, Brevis 35mm, Manfrotto 028,501,Vegas Pro 10e
Matthew Amirkhani is offline   Reply With Quote
Old December 29th, 2009, 09:53 AM   #2
There you go! The camera was trying to white balance on the closed curtain. For such a production, the tungsten preset would probably be your best bet.
Andy Tejral
Railroad Videographer
Andy Tejral is offline   Reply With Quote
Old December 29th, 2009, 11:17 AM   #3
Hi Andy,
Thanks for the information., is it possible for you to send me the Tungsten Preset?
Thanks in advance.
Matthew
Old December 29th, 2009, 01:24 PM   #4
The tungsten preset is one of the presets for WB it's the switch on top of the camera under the LCD screen
Kevin Myhre is offline   Reply With Quote
Old December 29th, 2009, 02:02 PM   #5
Better would be to manually set the white balance, but with the tungsten WB preset you'll at least get consistent color (won't change as the camera is constantly re-evaluating WB with AWB), and be able to correct in post. AWB is the pits. It not only usually misses the mark, but is also a nightmare to fix later - better having color that is noticeably off, yet consistent, than having it closer, but shifting throughout the footage.
Robert M Wright is offline   Reply With Quote
Old December 29th, 2009, 09:01 PM   #6
Thanks Kevin, everything is clear now.
Matthew
