Recording directly to the MAC
Has anyone tried to connect directly from the XH A1s to a MAC for recording to the computer without using the tape. I'm running FCP 7 as the editor. Please tell me your set-up for direct recording if you have done this process.
Thanks, Miles Hale |
Recording to mac
Miles,
I record using quicktime pro. In SD, I can record two inputs at the same time (1 using an expresscard adapter FW adapter). In HD, I record only one camera at a time, though I have not tried 2 HD sources. Simple FW hookup, there is a slight lag on the computer but it makes for a great backup. I have actually started using the computer as my main footage and the tapes as backup. Saves me a ton since I can now reuse the tapes. Hope this helps some.
Jonathan Schwartz CA Video Productions |
hi,
When I was home at Mom's I filmed all the 8 mm my Dad shot 50 so years ago. I plugged the camera into my Apple lap top, and it went right in. I saved the tapes, but used the computer to make DVD's. This saved me from having to download the tapes. Ken |
OnLocation
You can record straight to disk with Adobe OnLocation. It comes with Creative Suite. It also provides a complete set of scopes, etc, so you can monitor your levels while shooting. It's a little laggy, and you have to jump through a couple hoops (Google "Clip Wrap") to get the footage into FCP but you can go straight to disk this way.
