Need help with 30fps rate information at DVinfo.net
Old November 24th, 2009, 09:07 PM   #1
The XH A1 manual is sparse in the way it explains frame rate. Seems that when recording HD 30F then the spec would be 1080 30P. is this right? Also seems that the firewire port outputs this rate while component is converted to 60i within the camera. So if all above is right, then capture into FC Pro would be set to 1080 30P?
David Morgan is offline   Reply With Quote
Old November 25th, 2009, 07:46 AM   #2
You are correct.
Old November 25th, 2009, 09:48 AM   #3
thx for the reply. I guess I should have looked at the specs of my FS-H200 a little more carefully before I bought it. Turns out it doesn't record 1080 30p. I have to use tape again........
