How to attach both light & Receiver at DVinfo.net
Old October 30th, 2009, 03:19 PM   #1
Does anyone have any thoughts on how I can attach both an external camera light and wireless lav set up to the xha1. I wont be on a tripod so I cant attach it there.
Kevin Lewis is offline   Reply With Quote
Old October 30th, 2009, 05:06 PM   #2
I often use two wireless receivers. One attached to the top shoe slot and one clipped to the outside of the hand grip. It works well there for handheld shooting
Don Xaliman is offline   Reply With Quote
Old October 30th, 2009, 06:12 PM   #3
I saw something at B&H nearly a year ago that was basically a bar with two shoe mounts on top that attached to the camera shoe mount. That should solve your problem if the mounting the receiver to hand strap doesn't work. I like the concept because it moves the light a little off center and makes some shadows.
I once had a thought about using the shotgun mount to hold a piece of PVC and mounting a shoe receptacle to it. I never ended up doing it, but it should work.
Old October 30th, 2009, 06:26 PM   #4
Thanks guys. Tripp you have also addressed several of my posts in the past. Just wanted to say thanks. The advise i always helpful.
Old October 30th, 2009, 07:09 PM   #5
I have something similar to this light and sound bracket to this one here...
Light and Sound Video Bracket | L.A. Color Shop
Reggie Noble is offline   Reply With Quote
Old October 31st, 2009, 02:45 AM   #6
Kevin
I bought one of these for my XH-A1 in England and it works a treat see:Hague Triple Shoe Mount
Paul W. H
Paul W. Hazeltine is offline   Reply With Quote
Old November 1st, 2009, 07:36 AM   #7
there is also the oft mentioned j-rod .. Home (fellow NJer, but I don't know 'em).
Dave Stern is offline   Reply With Quote
Old November 1st, 2009, 07:51 AM   #8
The Rycote multimount is a tidy answer for your needs. Rycote - 037303 HOT SHOE EXTENSION pics here, posts 6 and 8 http://www.dvinfo.net/forum/sony-hvr...ml#post1414542
Colin
Colin Rowe is offline   Reply With Quote
Old November 2nd, 2009, 04:35 PM   #9
I use J-Rod. Works very well.
JJ
J.J. Kim is offline   Reply With Quote
Old November 2nd, 2009, 06:06 PM   #10
I second the J-rod. Works great on my A1.
Roger
My YouTube Channel: https://www.youtube.com/channel/UCAp...2AHr_pHFID5LDA
Roger Van Duyn is offline   Reply
