Question about Shutter speed
For those that frequently set the XHA1 to a shutter speed of 30 (shooting 60I) because of low light enviroments, have you noticed any problems such as trails? I have an event to film which will have low lighting. I want to keep the shutter at 30 for the extra light. I posted a similar thread in the past and someone said that trailing may be an issuie. I dont have much time to experiment before the event, and I just wanted to get some thoughts from others. I just want to make sure that when I go to edit, that I dont get some unexpected result. The event is a wedding.
Hi Kevin,
I always set my shutter speed at 30 when I film for interviews at night The reason is that I don't move the camera, however you will see some trailing if you pan. Matthew
Canon XHA1, Brevis 35mm, Manfrotto 028,501,Vegas Pro 10e |
Matthew:
Thats what I was told before, but I have yet to see trails. I'm wondering if the lcd is not showing the trails but they will be there when I edit. Do you notice the trailing live in the lcd screen or only when you edit? |
Hi Kevin, try Randy's low light preset PFVISION it's very good. Take care putting the numbers in, don't go below 60 speed.
http://www.dvinfo.net/forum/xh-serie...-included.html Cheers.
Drink more tap water. On admission at Sydney hospitals more than 5% of day patients are de-hydrated. |
#5 |
Hi Kevin,
I do see them in the LCD as I am filming. Matthew
#6 |
Matthew:
I have experimenteed with this over the last few days but could not duplicate a ghosting problem wehn filming 60I and the shutter at 30. I have an event next week and I will need as much light as possible. I torn between using the 30 or not. |
#7 |
Hi Kevin,
I also do some filming in the low light specially for school playes and concerts. For those occasions I always use the PFVISION preset, set the Gain to either 3 or 6 and open my Iris all the way. To be honest with you wihen I have to pan the camera I set the shutter speed to 60 so I don't get any ghostings. In post I do the color corrections and exposure and the rest. Hope it helps you.
