#76 |
Taky, to which light are you referring?
thanks |
#77 |
I'm talking about the SWIT S-2010 light. I have also Canon VL-10 as well as LitePanel Micro. LP MIcro looks cute but it's the weakest light among all. It's very flimsy too.
LA Color Pros Blog RODE Authorized Reseller . Comer LED Camera Lights . TakyBox HTML5 Menu Generator |
#78 |
I've tried the Canon,
Anton Bauer set up as well as the ikan iLED 100 Kit Each have their places but I really like the options in the iKan model and the overall set up of the Anton Bauer. |
#79 | |
Taky - Did you get to use the Varizoom light for your wedding this past weekend - If so, what is your impression of the light? I was thinking of getting this LED that will run off of my Panasonic batteries that I use with the DVX100. I currently use a Frezzi mini fill light with dimmer but I'm geting tired of carrying around the battery belt during the entire reception.
Thanks Quote:
#80 |
I used the SWIT light for the last 2 weddings. Overall I like it very much especially with the long battery life (i used it with the BP-970G battery). I like the flexibility of the light with the color temperture filter and the diffuse filter.
When I do close up interview, i will use the dimmer + diffuse filter so the object warmly lit without any harsh highlight. When I use it in reception, I remove the diffuse filter to increase the light intensity. If I need more light, I will remove the color temperate correction filter. The blue-tint is then fixed by a white balance preset in XH-A1. works well so far. Also, I mounted the light and the battery holder onto this hot shoe extended bar. So it's a lot faster to mount the light on and off. Rycote | 037303 Hot Shoe Extension | 037303 | B&H Photo Video I stop using the LitePanel Micro as it's not bright enough, and, I hate to change battery every hour. If I have time, I will post some footage.
#81 |
Taky - Thanks for the great feedback! I would love to see some footage from your weddings with the light in some of the scenarios that you talked about - especially the first dance under low light conditions where you have to stand at the edge of the dance floor.
Other questions - How wide is the spread of the beam of light? Do you shoot wide screen/HD? How long did your battery last and at what power? Did you need to switch batteries during the event? I have few long life Panasonic batteries for my DVX100 that I'd like to use since the new Panny HMC150 won't use the old batteries.(I'll be upgrading the cam before the next wedding season!) And if you have time can you post a photo of your cam with the light on the extended hot shoe bar. I'm have a mental block as far as visualizing the light and battery on the bar. Thanks, Mike |
#82 |
Go Cycle
I just tried the new Switronix Torch LED. It is self-contained 30 watts with a filter kit.... so I don't have to attach an external battery to my Frezzi anymore. It's suppose to last over two hours. I placed my order last week.
Switronix - Products
Lou Bruno |
#83 | |
#84 |
Have any of you heard of this led ligth 35w made by Bescor? :
Bescor | LED-35 On Camera Light | LED35 | B&H Photo Video It's only 189.00 |
#85 |
It would be nice if they stated it has a dimmer or not.
Resembles a re-badged LitePanel micro Edit: Actually it does not resemble rebadged LitePanel Micro |
#86 |
LP Micro vs. NRG Light
Hey all...
I searched the forums for info on this and found a thread from only about a month ago that dealt with lights, but it didn't really help give me an answer one way or the other, so I'm sorry if this may seem redundant. I am finally getting my XH A1. B&H is now listing the A1s, so the price has been reduced. I need a light was well (obviously) and want to make sure I get a good one (obviously again). B&H lists the LP Micro on their A1 page and the reviews I read say they are pretty good. But then I came across the previously mentioned thread which mentioned the NRG light and wondering which one would be best for what I am going to be using the camera for, which is weddings. I am kind of leaning towards the LP Micro, but any help that can be offered would be much appreciated. Thanks! |
#87 |
I purchased the LP Micro light and decided to send it back. It is good for a close-up interview light but does not have enough throw or wide enough spread to be good for more than 4 feet away. I have been using several lights and each has it problems. I use an Lowel ID-Light for grand entrance, first dance and speeches. I am usually on tripod so an external battery is no big deal. For the other shots I use a custom built light with 150 LEDs or my Sony HVL-20DW2 with a Stofen diffuser. I had some luck with a Swit S-2010 but the external battery/clamp is a pain. I have worked with some other shooters that use the Sony HVL-LBP which works very well but with the battery it makes the camera very top heavy.
Canon XH A1, Sony HVR-MRC1, Premiere Pro 3.2.0, Matrox RT.X2 LE http://www.scsvideo.com |
#88 |
I tried a LPmicro and returned it after the first day due to very low light output. Many people have written they are happy with them for close up work but even then I couldn't see how, it's just not much light. I also thought it was cheaply built and extremely overpriced. If I was going LitePanel I would pick a higher up in their product line to likely solve all these issues.
After returning the LPmicro I purchased a Zylight Z90 and power it with a Tekkeon battery and love it for many uses. I don't have any experience with the NRG light so I cannot comment there, sorry. All the best, James Hooey
For Stock Footage http://www.revostock.com/ViewProfile.html?&ID=4811 My Website http://www.soundprostudios.com |
#89 |
10 Watt Light Uses?
Hello all. I am finally going to use my new XH A1 for the first time this weekend at a wedding and now full of questions until then...
I have a 10 watt light sitting around from my GL2 sitting around that I never really used. It's only 10 watts, so very low light. Can anyone think of any practical use for it at a wedding? |
#90 |
If it's camera mounted, it may help getting interviews during the reception which is typically a low light situation. Other than that, I can't see it being of much use.
