XH-A1 On camera light! question. - Page 3 at DVinfo.net
Old May 1st, 2007, 12:07 PM   #31
Originally Posted by Mark Dixon View Post
I think I am going to go with the VL-1-Li :
http://www.bhphotovideo.com/bnh/cont...=144312&is=REG
I was talking with the salesperson where I bought the XH G1, and he said it should be sufficient, that lights with too much wattage will just create overexposed areas. This light also uses the same batteries as the camera so they can be re-charged with the recharger that came with the camera.
Mark
The saleman doesn't know what he is talking about, if that is the case you better not shoot outdoor because the sun has alot more wattage than that 10watts light. Get something that you can control the output, see what is important to you as far as battery or output, LED use less power but it is weak, halogen is brighter but use more power therefore needs more battery, I'm waiting for the Zylight Z90 to come out and see how it does, that seems to be the only one that would fit my need so far beside the LitePanel, although I need to check the Sony LED, I just don't know how it would blend in with tunsten light since it is an outdoor temperature. I"m currently using frezzi and it is great, just don't want to carry so much battery anymore.
I was hoping for Meryem to post a few pict of his light in action so I can see. hint hint (-:
Khoi Pham
www.proeditproductions.com
Khoi Pham is offline   Reply With Quote
Old September 10th, 2007, 01:48 PM   #32
Sima SL-9 Video Light 3-Watt
I am not so pleased the XH-A1 doesn't provide the Canon Advance Accessory Shoe invented. I need a small light like the Canon VL-3 so I can light an near object such as an interview. The Canon VL-10 is too bright for the purpose causing the object looks all washed out.
I found this product that rated also 3-Watt just like the VL-3. It works great. It's also very cheap too!
http://www.simaproducts.com/products...product_id=105
However, if you ordered from their web site, you will also need to call them. Otherwise, they will ship you the SL-9X which is the silver body color version.
Old September 10th, 2007, 03:35 PM   #33
that's a handy little light. thanks for the heads up on this taky.
i'm going to pick one up.
Eric Weiss is offline   Reply With Quote
Old October 26th, 2007, 06:14 AM   #34
What light is good for A1 + Merlin combo?
I'm using the A1 on the Merlin. Currently also using a Vitacon WA lens which is pretty heavy. I'm going to change it to a 16X9 inc or other light weight WA lens in future. Will be fixing a Rode NTG-1 mic too.
I am wondering what light is suitable to be used on the A1? Taking into account all the accessories, I think it is going to max out my metal Gimbal Merlin capabilities, so need some lightweight lighting. Any recommendation? :)
Kenny Shem is offline   Reply With Quote
Old October 26th, 2007, 07:05 AM   #35
go and check out red eye for the W.A lens and vidled lights. It think it might fit the weight of the merlin
David Chia is offline   Reply With Quote
Old May 6th, 2008, 12:40 PM   #36
Camera light with 3-pin XLR
Is there any on camera light that get power from the XLR on A1? Is it even possible? I noticed all the XLR lights are 4 pins.
LA Color Pros Blog
Old May 6th, 2008, 03:26 PM   #37
Contributor
The XLRs on the camera are audio inputs only. You'll need a battery belt or battery pack with the 4 pin power cable.
Old May 6th, 2008, 04:08 PM   #38
That's what I thought so too! thanks for clarifying.
LA Color Pros Blog
Old May 18th, 2008, 02:05 PM   #39
What on-camera light are you using?
I have had a Mini-Cool light for years which was fine for 4x3, but now it is just not wide enough for 16x9. Lite panels are too expensive and the wrong color temperature since most of my shooting is indoors. Other LED lights don't seem to have the throw of incandescents.
Is there an incandescent which covers the whole wide frame evenly?
John Markert is offline   Reply With Quote
Old May 19th, 2008, 09:30 AM   #40
Man, I hate to see a post for help with no reply.
I don't know if it helps you or not, but I've got the VL-10li II video light from Canon and I am pretty happy with it. But I don't know the area you are trying to cover. I do product installations and really just need to light the area of interest (engine compartment, underneath a truck, in the trunk of a car.)
Those are my two cents.
Will Mahoney is offline   Reply With Quote
Old May 20th, 2008, 05:40 AM   #41
Go Cycle
I use the Sachtler Reporter with the spot feature and dimmer. Looks "cool" also.
Lou Bruno
Lou Bruno is offline   Reply With Quote
Old May 20th, 2008, 10:15 AM   #42
I used to have the dedicated Canon light on my XL2, but I sold it with the camera, because I found the beam too narrow. I'm using a Bebop light now on my XH-A1, with a seperate Pro-X battery. It has barn doors & the daylight filter. Works great.
Old May 20th, 2008, 11:17 AM   #43
I also use the VL-10li, it's not amazing, but uses the same battery as the camera which comes in helpful.
www.tallyproductions.co.uk
Kathy Stannard is offline   Reply With Quote
Old May 20th, 2008, 12:09 PM   #44
Hi,
I use a Sunpak RL20. It is cheap and very bright, however the short battery life mean you might need a couple of them. (I don't know if they have replaceable batteries)
http://www.bhphotovideo.com/c/produc...e_15_Watt.html
-Steve
www.spreefilms.com - Give me a museum and I'll fill it!
Steve Lewis is offline   Reply With Quote
Old May 20th, 2008, 05:56 PM   #45
I am using two VL-10 together mounted on a flash bracket that takes 2 accessoires side by side on the top bar. It works very well especially in dim hotel ballroom.
For close up interview purpose, I use LP Micro. The dimmer is great.
LA Color Pros Blog
Taky Cheung is offline   Reply
