#16 |
So...
All of you who say to set the low gain to -3 are dead wrong??? This guy got great shots with +6 and +12. Please explain.
Anyway, I called Canon and the tech talked me through resetting my camera. It didn't work the first time, but after the 2nd reset my picture started to look good - with a little noise when I boosted the gain. I fired up both my cameras and they matched up. I hope it stays that way. Now, I'm ready to try some of the presets I've collected on your site. Thanks for the help. Last edited by Alex DeJesus; August 14th, 2009 at 07:10 PM. Reason: Update on situation |
#17 |
Alex, anyone who suggests -3dB aren't "dead wrong". It's just what works for them and certain scene situations. I use it myself, depending on a scene. You're right that if AGC is on and in an outdoor situation like the still you posted, it shouldn't kick in. Mine doesn't (even though I never use it) and that's the way it is designed to work.
Anyone who is getting noisy images such as yours either has a faulty camera, or is doing something horribly wrong. Last edited by Bill Busby; August 15th, 2009 at 02:30 AM. |
#18 |
I Forgot To Mention
Before we 'Reset' the camera, I did notice it was in the "Cine" preset even though that alone should not have caused all that noise. Anyway, it looks decent now. I'll take it.
#19 |
Alex I assume you spent a good chunk of money on the camera so why not use it to it's full potential?
Set it to M. AGC off. Gain set to -3. Shutter speed 1/60. Adjust aperture according to how brightly your scene is let. If you still get grainy images either you camera is broken or your monitor is crap. |
#20 |
Reset the camera to 'factory' condition - BEAUTIFUL!
Did a shoot last night. I guess resetting the camera worked. Push a paper clip into a small hole under the LCD screen - next to the speaker. Make sure you feel the detent, hold for 10 seconds. I had to do it twice. I had to re-customize the camera afterwards.
The only other possible culprit was before resetting the camera, I noticed that it was in one of the "CINE" presets, which is designed for shooting in 24f. I had been shooting in 30f and 60i. In my opinion, though, it should not have caused that much noise. |
#21 |
Hi All,
No mention yet has been made of the possible mistake of having the ND filter engaged. I did this once and was mystified why my video looked dreadful till I noticed the problem. Cheers Alan. |
