XHA1 and 5D MkII at DVinfo.net
Old June 30th, 2009, 09:38 PM   #1
XHA1 and 5D MkII
Hi.
Anyone tried to match the A1 with the 5D?
Any custom preset out there?
Thanks.
L.R.
Luis Rolo is offline   Reply With Quote
Old July 13th, 2009, 08:46 AM   #2
I don't have the answer, but a bump for a great question.
Anthony Martin is offline   Reply With Quote
Old July 13th, 2009, 04:40 PM   #3
I find Vivid RGB is the closest without tweaking presets too much.
I'm using Neoscene to convert all 5D footage to 29.97fps. I shoot everything on my Xh-A1 at 30f witch is actually 29.97fps as well. Put it all together on a 29.97fps timeline in Premiere CS3 and you are good to go. Looks awesome!
www.scott-gold.com
Scott Gold is offline   Reply With Quote
Old August 2nd, 2009, 04:05 AM   #4
Is it possible to apply this preset on the Canon 5D Mark II DSRL? I've just seen a wonderful video on Vimeo that was shot using these parameters and I was wondering if I could do the same on the 5D.
Here's the video:
Monday - HD on Vimeo
Here are the parameters:
Gamma: Cine1
Color Matrix: Normal
Color Gain: 25 (This is about the limit. Adding more color does very little to enhancing chroma and does a lot for introducing unwanted noise)
Color Phase: 0
Knee: Low
Black: Middle
Master Ped: -5
Setup Level: 0
HDF: Mid
H/V Detail: 0
Sharpness: 0
NR1: Off
NR2: Off
Coring: 0
Red Gain: -2
Green Gain: -2
Blue Gain: -3
RG Matrix: 0
RB Matrix: 0
GR Matrix: 0
GB Matrix: 10
BR Matrix: 0
BG Matrix: -13
Felipe Tavares is offline   Reply With Quote
Old August 2nd, 2009, 10:28 PM   #5
there's no link
Old August 9th, 2009, 09:09 AM   #6
Luis,
I did some tests are while back for this: NaturalO (from the preset stickies here on DVinfo) on the XHA-1 and Standard setting on the 5D2 work closely together. Fix the white balance on both to daylight (you are best to do this on the 5D2 anyway - the AWB setting will give mixed to nasty results). Any fine tuning can be done in post.
For footage, convert both to ProRes LT and mix them there.
Nick.
Very important: set the 5D2 to shoot in sRGB, not Adobe RGB or you will have big problems with colour
Nick Wilcox-Brown, Film-maker and Photographer
https://nickwb.com https://wildphotographer.co.uk
Nick Wilcox-Brown is offline   Reply
