Shooting memorial stones
I have a problem with shooting memorial stones. The headstones and plaques are white with the names just cut out of the stone (i.e. not coloured). The sun shines directly on to these stones throughtout the day (they face south) and I am trying to figure out the best way to get good clear imagery.
I am going to France next month to film WW1 cemetery footage. I have been practising at home with similar headstones (people must think I'm mad!). Any sugestions anyone? |
Contributor
Shoot in the early morning or late evening when the sun is at an angle.
Take a white transparent umbrella from a lighting shop or Ebay, to diffuse the light. Get someone to hold it in position or take a lightweight tripod.
Cheers. |
You might also try using a polarizing filter to cut down on reflections. I've used them with success on similar surfaces. Shielding the light with a white umbrella as mentioned above is great too and will reduce glare and contrast.
#5 |
Hi Philip..........
The standardised military headstones in Europe are best shot using a seperate light source to force a steeply angled shadow using the engraving.
This can either be a reflector (not all that easy if South facing as the angles just don't work) or a powered light system of some sort. Using the previously mentioned suggestions of a light shade and a shadow light should hit it off about right. Keeps the contrast easier to deal with as well. Bit of a bugger if shooting "one up" as there won't be enough hands to go 'round. CS |
#6 |
Thanks for the tips. I'm going to have to try several shots I think using a combination of techniques
#7 |
Hi Philip,
I will be visiting the Somme in November and will also be shooting in a couple of war cemeteries. A bit of a cheek I know, but it would be great if you could post the results of your filming once you get back, with info about the technique used. Good luck with it. Colin |
#8 | |
