What is the name of this wire connector?
Hey,
I need to know what the connector on this wire is called. I don't need the same of the whole wire, just that one peice. It's the black end and plugs into the XHA1, not the component end. Here's a pic: http://ecx.images-amazon.com/images/...-L._SL160_.jpg Thanks
Check out my blog at KevinSawicki.com |
It's commonly referred to as a D-Terminal.
Not sure, since that's a really small pic and it doesn't look like the same component cable supplied with the A1, but if you're talking about the A1's connection it's called a D4 connector.
I have a monitor that has the D-terminal connector on it... but not component inputs... So I am looking for a d terminal to d terminal wire.
#5 | |
[edit:] Okay, here's everything you need to know about that connector: http://wapedia.mobi/en/D-Terminal Except, I guess, where to buy... hmm. |
#6 |
Well, knowing what it's called is half the battle. Can't do an internet search on"well, it's a thingie about so wide with five pins and a couple RCA plugs on on the other end."
Martin
Canon XF300, Canon 5DMkII, Canon XL2, Rolls MX422 mixer, Zoom H4N, AT899 lavs, AT2020's, Azden SGM 1X shotgun, Manfrotto 501 head on 351 tripod |
#7 |
Chris, I was just going by what B&H had for the description of the cable.
I was looking at that picture posted the other day again and it's funny how one day you look at something & see it differently the nest time around. At first I didn't think that was the right component cable for the A1. It's the orientation of the connector that threw me the first time. Strange how the brain works :D |
#8 |
The monitor I have is in japanese, kinda like this - http://pic.srv6.wapedia.mobi/thumb/6...at=jpg,png,gif
Instead of D4, it says D2. Can anyone find a link for a D2 wire? If I plug the XH into a D2, will it receive the signal?
#9 |
Is this the connector?
Cowon D2 EXT plug pinout and signals @ pinouts.ru |
#10 |
D2 supports only 480p resolution. It won't accept 1080p. However, you can set the XH A1
to downconvert to 480i over component video output, so this shouldn't be a problem. |
