Is there a converter for XH-A1 from component to HDMI Cable ? at DVinfo.net
Old April 15th, 2009, 05:37 PM   #1
Is there a Converter that plug into the Canon A1 or H1 Terminal and has an HDMI Cable on the other end ? I know you will only get picture, but is there anything like that exist ?
Michael Ojjeh is offline   Reply With Quote
Old April 15th, 2009, 06:32 PM   #2
Hi Michael,
Try this:
Let me google that for you
Joel Peregrine is offline   Reply With Quote
Old April 15th, 2009, 06:45 PM   #3
There can be no such device according to HDCP law, so if you find one... call crime stoppers and collect your reward. The closest thing would probably be a switch though. But that would be like 200+ cause it is like a receiver for home theater, and prob would give u same quality anyways...
Just a link on HDCP
High-bandwidth Digital Content Protection - Wikipedia, the free encyclopedia
University of Windsor student. Trying to find funds for gear...
Bradley Ouellette is offline   Reply With Quote
Old April 15th, 2009, 06:52 PM   #4
Originally Posted by Joel Peregrine View Post
Hi Michael,
Try this:
I am looking to replace the Component Video Cable (DTC-1000), you would think Canon will come up with such cable, I guess not !!!
Old April 15th, 2009, 07:02 PM   #5
Re dtc-1000 cable, available many places on-line, here is one:
Canon DTC-1000 D Terminal Component Video Cable - EC7670 - 0976B001AA /Battle Vaughan/miamiherald.com video team
Old April 15th, 2009, 07:13 PM   #6
I am sorry, I was not clear, I am trying to replace the Canon DTC-1000 with the same end that pluges into the A1 and an HDMI on the other end.
Old April 15th, 2009, 08:45 PM   #7
Images: 18
Hi Michael........
There is no such thing as a Component to HDMI converter cable, simply can't be done.
If you wish to watch a tape produced with an XH A1 on a screen fitted with a HDMI port, buy a second hand HV20 or similar which does have a HDMI output and play it on that.
Works exceedingly well.
CS
Old April 16th, 2009, 12:26 AM   #8
Can't do it with a cable, here's an adapter box:
Component Video + Digital Audio to HDMI Converter
Don't know what the quality will be like though.
Richard
Richard Hunter is offline   Reply With Quote
Old April 16th, 2009, 12:40 AM   #9
I don't know for sure, but one of these might work
There are many component video to HDMI converters, but I never tested one. The specs should be good enough. Try one of these links:Component Video + Analog Audio to HDMI Converter, or: Component Video + digital audio to HDMI Converter - HDMI 1.3b and 1080p Rated - HDMI 1.3 RATED DEVICES . Copy protection should really be no issue here, because you own that material, unless you want to copy protect it. In that case I don't think you could do it with these boxes.
Pavel Houda is offline   Reply With Quote
Old April 16th, 2009, 12:53 AM   #10
Images: 18
Er.......
Why?
Pretty basic question.
CS
Old April 16th, 2009, 02:42 PM   #11
Originally Posted by Chris Soucy View Post
Why?
CS
Pretty basic answer.
The output on the XH-A1 is an analogue component video signal with no audio.
HDMI is a digital component signal that also carries audio. You can only transform this signal with an analog to digital converter and this won't happen in a simple cable. You need some electronics to do this, like a Blackmagic Intensity Pro video card in your computer or some HD TV sets.
Don Xaliman is offline   Reply With Quote
Old April 16th, 2009, 03:56 PM   #12
Just a link on HDCP
HDMI can use HDCP to encrypt its data, but it's not required. If I author a non-encrypted DVD and play it through a system incorporating HDMI, the signal is not encrypted.
Larry Shilkoff is offline   Reply With Quote
Old April 16th, 2009, 07:17 PM   #13
Why?
CS
It will be nice to have a 2f HDMI cable then the 10f Canon DTC-1000 cable hooked up to a monitor on your camera.
All LCD TVs have HDMI connection on the side NO Component input, It is a pain to hook-up in the back of a TV especially when it is mounted on the wall.
