Green "Lights" - UV Filter the cause at DVinfo.net
Old April 15th, 2009, 04:41 PM   #1
I have a brand new XH-A1S. Have experienced some green "lights" that are sort of ghosting against objects when pointing the camera toward lights and candles. If I remove the UV filter, problem solved. Clean the new Canon UV filter, reinstall - problem is back. Defective UV filter?
Don Kinsley is offline   Reply With Quote
Old April 15th, 2009, 04:43 PM   #2
You might try a high quality multicoated filter, if indeed you need one.
David W. Jones is offline   Reply
