HDV exporting issues with Premiere CS3 at DVinfo.net
Old March 14th, 2009, 02:46 PM   #1
Hi,
Can anyone help me with an issue I am having? I am trying to export an HD video in Prem. CS3 using either Windows AVI or Quicktime. However, it is rendering out in Square pixels instead of widescreen. How do I fix this?
Any help would be greatly appreciated.
~Jason
"...The keenest eye is that which looks inward"
Jason Sharaba is offline   Reply With Quote
Old March 14th, 2009, 03:23 PM   #2
I don't have PP but I use the rest of the CS3 suite... In Ae you can change the comp settings and square pixels is an option. I thought the layouts were suppose to be very similar so maybe there is Comp Settings or similar setting in the pull down menu.
Tom Sherwood is offline   Reply With Quote
Old March 14th, 2009, 03:55 PM   #3
Thanks for the reply Tom. I see your point.
However, I must learn how to do it in Premiere. What I don't understand is when I burn to DVD the aspect ratio is perfect. It is only when I export to avi or quicktime does it default back to 4:3 instead of 16:9 widescreen.
Old March 14th, 2009, 03:56 PM   #4
It sounds like you are exporting at 1440x1080 with a 1.33 pixel aspect ratio, which some players have difficulty interpreting.
Export at 1920X1080 or 1280x720 using square pixels.
Kevin Dorsey is offline   Reply With Quote
Old March 14th, 2009, 04:44 PM   #5
THANK YOU!! THANK YOU!! THANK YOU!! THANK YOU!! THANK YOU!! THANK YOU!! THANK YOU!!
It worked!! :)
Old March 14th, 2009, 05:39 PM   #6
Here is the webpage that I got it to work on. Once again, thank you so much for your help!
Linda D'Amico's Academy of Dance Facility
