On Camera Lighting.. at DVinfo.net
Old March 8th, 2009, 06:46 PM   #1
I know often debated on the forum..
I had purchased a Litepanels LPMICRO Micro LED on Camera Light.
I thought the light did ok at the house..but really didn't need it as it was well lite.
But once I got to a reception hall found it to not have the right amount of kick that I needed..So what do you think the best on camera light is for the XH-A1? I use to have the blue Frezzi light with my DVX..I thought it was good power..but often times just too bright..I know I can adjust the amount of light..but their wasn't a good sweet spot..
maybe it's something I am doing incorrectly..
any thoughts?
Peter Ferriero is offline   Reply With Quote
Old March 8th, 2009, 07:38 PM   #2
I use a Sachtler 75H Reporter and it is ok, it's good due to being dimmable and also you can focus the light.
Jonathan Shaw is offline   Reply With Quote
Old March 8th, 2009, 08:33 PM   #3
what does it use for power? battery?
any links?
Old March 11th, 2009, 07:07 PM   #4
I use the Frezzi micro model with a dimmer and the softbox. You may want the larger one. For outdoors, you can put a CTB gel inside the softbox instead of sacrificing the softness for the dichroic filter.
Old March 11th, 2009, 08:31 PM   #5
Here you go Peter
Sachtler | Reporter 75H Head, XLR Cable, Dimmable | R75HD | B&H
Jon
