Sound problems with XH-A1 at DVinfo.net
Old March 6th, 2009, 04:50 PM   #1
Haven't really been noticing this because sound wasn't such a big issue for the things i shot. But i'm noticing a lot of static on both the internal mic and external mic. Attenuator is off, controls are set to manual and both channels are midway.
Tried two different XLR-cables, but as both internal and external mic have the same static i'm ruling problems with the cables out.
I have uploaded an example: Geluidstest on Vimeo
(it could still be converting)
Canon XH-A1 was bought in may 2007. Couldn't find any known issues quickly. Anybody got an idea?
Emiel Labree is offline   Reply With Quote
Old March 6th, 2009, 04:57 PM   #2
AGC is off also?
Is the static present in playback also?
IF AGC is off and you are not peeking the audio....you may have a problem.
Michael Hutson is offline   Reply With Quote
Old March 6th, 2009, 05:06 PM   #3
Originally Posted by Michael Hutson View Post
AGC is off also?
Yes, also present in playback.
AGC is off and no peeking in the audio.
Any known issues with certain serial numbers perhaps? Could this be (easily) fixed by a repairdesk?
Old March 6th, 2009, 10:27 PM   #4
Emiel,
I listened to the audio and it sounded like the AT897 shot gun mic you are using produced a lot more hiss than the onboard mic. The sad fact is that many sub $1,000 shotgun microphones can produce quite a bit of self noise that comes from the pre-amp in the mic.
I have an Audio Technica shotgun mic as well that I use on my A1. It's the longer 15 inch model (I don't remember the model number) and when it's very quiet I can hear some hiss as well. It's really not noticable during normal shoots.
I believe that your mic runs off a battery or phantom power. I also know that the mic performs a little better running on phantom power. Double check to make sure your mic can use phantom power. If so, remove the battery and turn on the phantom power on the A1.
If you can, try connecting a dynamic mic to the A1 and see if the hiss is still there. It shouldn't be since the dynamic mic doesn't have a pre-amp like AT897 which uses a condenser mic. I've done that test and, at least in my case, the hiss went away. Of course the condenser mic, overall had a better sound for what I was using it for.
By the way, thanks for making me practice my Dutch! I'm still a little rusty but I think I understood most of it. LOL. (originally from Den Haag many years ago)
_______________________________________________________________________
Canon XHA1 * SGBlade 35mm adapter -RR1, RR2 w/ Optics Upgrade * DIY Mid-Format adapter
Marcel D. Van Someren is offline   Reply With Quote
Old March 7th, 2009, 03:26 AM   #5
Originally Posted by Marcel D. Van Someren View Post
Emiel,
In Vegas i pushed the db even higher to make it hearable. It this really normal for levels about midway? I'm not really hearing a difference in hiss, but i'm no professional.
I'm on phantom power.
Hehe, it's just me mumbling and getting disorientated by the delay through the headphones.
Old March 7th, 2009, 05:37 AM   #6
Tested at a louder volume and you're right. The external mic is producing much more hiss. How to solve this?
And BTW, you're correct is the AT897.
Old March 7th, 2009, 07:59 AM   #7
With a battery in AT897 the hiss is gone!
Old March 7th, 2009, 08:40 AM   #8
Well that actually makes sense. According to what i've read on the mic, phantom power increases the sensitivity of the mic. I'm assuming that is because there is more voltage from phantom power than the battery. The pre-amp has more power and could be causing some of the hiss.
Regardless, I'm glad to hear that you've solved your problem.
