Tekkeon Battery with XH A1 at DVinfo.net
Old February 23rd, 2009, 03:18 AM   #1
Has any one used this? The camera requires 7.4 volts and the closest option on this variable voltage battery is 7.5
Tekkeon | MP3450 myPower ALL Universal Rechargeable | MP3450
As I understand it, listed voltage requirements are nominal so I'd find it hard to imagine that the extra .1 volt would be an issue. That said, I'd rather not assume.
Also wondering if any of the 9 connectors that come with the battery work with the camera and if not, what you used to make the connection.
I've got the same question about using this with an HV 30 so I'm going to post this over there as well. Trust this won't be considered a double post.
Jase Tanner is offline   Reply
