PRESETS: How to install from Card to Camera at DVinfo.net
Old January 9th, 2009, 01:55 PM   #1
I have looked on page 81 in the manual and have tried to load from card to tape. I do not see the the name of the custom preset that I want to load to the card. I have the file listed as PRESET and down loaded the presets from the DV i network. I have also called Canon about the issue. PLEASE HELP ME. This is my first post and their is a lot of information on this site.
John Crabtree is offline   Reply With Quote
Old January 9th, 2009, 02:23 PM   #2
I may be telling you some things that you all ready know, but I'll include them just in case:
1) you'll need a card reader to connect to your PC. They are very inexpensive but you need one or something that has one. Many newer printers have built in card readers. This will let you add and remove things from the card as long as it is connected to the PC.
2) Once you create a folder call PRESET on the card, you can load up to 20 presets to that folder. Any more won't be recognized by the camera. You must have the files named correctly - ie PRESET01.CPF, PRESET02.CPF, etc.
3) once the card is back in the camera, you cycle through the presets until you find the one you want, and then turn it on using the preset button on the bottom left side of the camera under the menu button.
Marcel D. Van Someren is offline   Reply
