Monopod use Canon XH A1 at DVinfo.net
Old December 19th, 2008, 03:48 AM   #1
hello,
sometimes I like the use of a monopod with my camera. I know the use of a monopod will not give a perfect result.
What kind of monopod is adviced or which one do you use?
Wil
Wil Vermeesch is offline   Reply With Quote
Old December 19th, 2008, 04:50 AM   #2
It kinda depends upon what you want to do with it. I tried using a monopod that I bought for my DSLR for some run-n-gun shooting at a motor race in the pits (paddock). It didn't really work. But I expect that I would have better luck if I was running around trying to catch some wildlife because of the increased mobility it provides.
You said that you like the use of a monopod. Are you using one now? If so, does it do what you want? If not, what's it missing? That info will help us point you in the right direction.
Old December 19th, 2008, 05:06 AM   #3
I got a manfrotto monopod with the same plate the I use on my tripod and Fig Rig so that I can switch from one to the other quickly.
I've only used the monopod when I didn't have space in my kit for a tripod. It has been useful on those rare occasions.
http://www.gooderick.com
Richard Gooderick is offline   Reply With Quote
Old December 19th, 2008, 09:38 AM   #4
Which type of monopod?
Old December 19th, 2008, 12:58 PM   #5
check out the manfrotto 561B awsome i use mine all the time
Robert Bec is offline   Reply With Quote
Old December 19th, 2008, 01:52 PM   #6
Ditto on the Manfrotto 561B, using the same plate as my tripod. I find it more stable than handheld for long duration shots, while keeping mobility for tight quarters.
Mark L. Whalen is offline   Reply With Quote
Old December 19th, 2008, 04:41 PM   #7
Also, Manfrotto 561B. Works well for it's intended use. That said, I sometimes (auto and motorcycle shows) use the monopod collapsed and place it's foot inside of a fanny pack pocket for support. I can walk around all day and run/gun without problems.
Don Maldos is offline   Reply
