XHA1 audio playback problem at DVinfo.net
Old December 10th, 2008, 01:22 PM   #1
Anybody has an explanation?
When playback there is no sound coming from the speaker. The sound is perfect when using headphones.
I've look into the troubleshooting section and sound playback section of the manual.
I've check the sound volume.
Please help.
Measure twice, cut once!
Robert Morane is offline   Reply With Quote
Old December 10th, 2008, 04:38 PM   #2
Please help.
I can only suggest the obvious - the LCD must be swung out or the internal speaker mounted underneath it will be switched off. You definitely have the LCD out?
The headphone jack shares the same volume control as the speaker - the SELECT/SET dial on the rear - there's no separate level control for the built-in speaker. So if you can hear the audio on headphones, withdrawing the jack should make it play out loud.
Other than that, it looks like there might be a fault with the camera.
Colin McDonald is offline   Reply
